94 prelude Si tranny problems
Old Sep 14, 2005 | 12:44 PM
JDM-Forti's Avatar
Default 94 prelude Si tranny problems
I have a 94 honda prelude with a big problem I can not get the car to go into any gear when its ON, even if I try to slam it in the gear. When that car is OFF the gears go in real smoth but i can not figure the problem. I did hear a sound coming out of my tranny, it souded like a bunch of keys shaking. Also if it helps that cluch is realy soft. One good thing the engine those work like knew. Any help or comments are welcome. Thank you
Old Sep 14, 2005 | 03:01 PM
Gearspeed-Performance's Avatar
Default Re: 94 prelude Si tranny problems (bugsy2002)
Seems like you may have an engagement (clutch/slave etc.) issue versus a trans issue.
Old Sep 14, 2005 | 08:50 PM
JDM-Forti's Avatar
i'll check the slave cylinder and i'll have to take out the tranny so i can check it out. Thank you
BUGSY
Old Sep 14, 2005 | 10:09 PM
mgags7's Avatar
slow down turbo, check the clutch cylinders and bleed it before you take the tranny out....
Old Sep 15, 2005 | 08:01 AM
JDM-Forti's Avatar
I'll check the whole system and bleed it and i'll make the tranny removal my last option. thank you.
dopefeen
Jul 15, 2006 09:04 AM
viprcr1
Nov 4, 2004 08:55 AM
90civichb
Dec 19, 2002 09:06 PM
1fastdc2
Nov 4, 2002 02:09 AM
93 EH3
Aug 13, 2002 02:55 AM
