cross threaded axle nut and/or axle
Old Sep 14, 2005 | 12:22 PM
dextR's Avatar
Default cross threaded axle nut and/or axle
i don't know if this is the right forum or not but i'll ask anyway. if the axle nut has been cross threaded, which part is actually messed up. the threads on the axle nut or the threads on the axle or both? just wondering so i can have the parts i need before i cut the thing off. thanks
Old Sep 14, 2005 | 12:24 PM
Splat's Avatar
Collector-o-Guns and Drinker
Where you been, Cliff?
Can you tell from the inside of the nut if it's damaged or not?
Old Sep 14, 2005 | 12:41 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (Splat)
You wont know until you cut the nut off. Unless the end of the axle is noticeably fubar'd.
Old Sep 14, 2005 | 12:50 PM
typer_696's Avatar
Default Re: (walker111)
GET a really strong impact on take it off, you will then be able to tell if you want to rethread which is not worth the time and be a lot easier to replace it
Old Sep 14, 2005 | 01:05 PM
Jowee's Avatar
Default Re: (typer_696)
How the hell did that happen? I would just a really strong impact to rip it off then diagnose the probelm from there. If the nut itself is messed up, that's only a few bucks from the auto store. If it's the axle, just get it rebuilt.
Old Sep 14, 2005 | 01:46 PM
cool guy name
Default Re: (Jowee 1162)
I personally would cut it off, trying not to mess it up more.
Old Sep 14, 2005 | 01:52 PM
Arsenal's Avatar
Seeing as there is a thread on driveshafts,
If you hold the drivers side shaft, should there be a little bit of play between the hub and the inner shaft. Ie, you can push it or pull it a couple of mm's? it seems locked in and I can't pull it out, but just wondering, thanks
Old Sep 14, 2005 | 01:55 PM
cool guy name
Default Re: (Arsenal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal &raquo;</TD></TR><TR><TD CLASS="quote">Seeing as there is a thread on driveshafts,
If you hold the drivers side shaft, should there be a little bit of play between the hub and the inner shaft. Ie, you can push it or pull it a couple of mm's? it seems locked in and I can't pull it out, but just wondering, thanks</TD></TR></TABLE>
Are you trying to pull the tree out of the boot? It wont. If not I dont understand what your talking about.
Old Sep 14, 2005 | 03:21 PM
Arsenal's Avatar
No, not trying to do that, it just seems like there is somefree play between the hub boot and the trans. end boot, like you can hold it, and slide it in and out slightly
Old Sep 14, 2005 | 03:26 PM
migs's Avatar
Get a strong impact gun using an IMPACT socket. There is a HUGE difference from an impact socket compared to a chromoly socket.
Second, pull the axle out and have it rethreaded. This can be done and I personally have done it myself. If you cannot find anybody to rethread the axle, have it replaced. Get a new nut as well.
Old Sep 15, 2005 | 03:58 PM
dextR's Avatar
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
Can you tell from the inside of the nut if it's damaged or not?</TD></TR></TABLE>
I've just been hanging around. Talk to Chris lately? I'm finally buying a house, though. It's kind of hard to tell what's messed up. I tried taking the nut off, but was only able to loosen it about 3 turns. I guess I'll just try cutting it off, I don't have access to air tools.
Old Sep 15, 2005 | 09:20 PM
ProjectDarkBlack's Avatar
Default Re: (dextR)
I had this happen to me, trying to rush things. I ended up grinding out 3 rows of thread on the axle and I bought a new nut. The nut on the end is not absolutely becessary but the axle can and will slide side to side a lot with out it (I drove without it for a few days, not recomended)
Old Sep 16, 2005 | 07:49 AM
cool guy name
Default Re: (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">I had this happen to me, trying to rush things. I ended up grinding out 3 rows of thread on the axle and I bought a new nut. The nut on the end is not absolutely becessary but the axle can and will slide side to side a lot with out it (I drove without it for a few days, not recomended)</TD></TR></TABLE>
I think that would be asking to tear things up.
grjr
Aug 23, 2012 04:12 PM
dynamo
13
Nov 14, 2005 08:22 PM
EFM_ookie
16
Aug 14, 2005 09:27 PM
david90
May 20, 2004 01:49 AM
Feb 19, 2004 08:54 PM
