Could not wiring in your knock sensor cause other codes to come up?
Old Sep 14, 2005 | 11:30 AM
9hatchman4's Avatar
Default Could not wiring in your knock sensor cause other codes to come up?
I have a 94 civic si with a boosted gsr motor in it. I haven't hooked up the knock sensor yet, and once I boosted it I started throwing codes 3,7,23,41, and 43. Now I know code 3 is tps, is this because not having the knock sensor wired it throws it into safe mode? Also 7, I believe is map sensor, but that is because It's reading boost, 23 is knock sensor, and then 41 is fuel supply system. Could throwing 41 be because of a bad O2 sensor which is 43. Just need some help, I'm trying to clear these codes before I run at the track this weekend. Any help is appreciated.
Old Sep 14, 2005 | 12:40 PM
9hatchman4's Avatar
Default Re: Could not wiring in your knock sensor cause other codes to come up? (9hatchman4)
bump
Old Sep 14, 2005 | 12:53 PM
jameskersten1's Avatar
What are you using for Management? Do you have a Missing link for the map?
Old Sep 14, 2005 | 01:33 PM
9hatchman4's Avatar
Default Re: (jameskersten1)
I should be getting my msd 3 bar map today, and I'm running an S-AFC right now...I'm going neptune as soon as I upgrade my turbo.
Chris Cleary
Feb 26, 2018 03:01 PM
birds_sol_94
Aug 19, 2004 04:23 PM
CandyRedHatch
May 5, 2003 08:31 AM
c1hatch
Aug 15, 2002 09:10 AM
