rhd crx ecu ? need help
Old Sep 14, 2005 | 10:07 AM
91jdmhatchback's Avatar
Default rhd crx ecu ? need help
I have searched everywhere and keep coming up with the same info. What i need is some info on the best fuel management (fe:uberdata) for a b16 with a full-race st 2 turbo kit. I'm in the process of doing the rhd conversion and found out you can't use the pw0/pr3 for boost. so i'm stuck tring to find some sort of fuel management other than a hack. i also am using the jdm wiring so i keep the cliamete control,and use my jdm doors that came with the clip. so if anyone could help me with this i would really appreciate it. thanks in advance.
Old Sep 14, 2005 | 10:19 AM
Slomo_civic's Avatar
Default Re: rhd crx ecu ? need help (91jdmhatchback)
why would it matter if it was rhd a lhd
Old Sep 14, 2005 | 03:14 PM
Default Re: rhd crx ecu ? need help (Slomo_civic)
the car is all ready wired for vtec and all the software like turbo edit uses the ac control to activate vtec. and uberdata requires obd-0 to obd-1 harness, but has the wireing coming of to the side like for a non-vtec car. so anyone with some answers?
Old Sep 14, 2005 | 07:00 PM
anyone?
Old Sep 14, 2005 | 07:21 PM
bump
Old Sep 14, 2005 | 07:47 PM
NikoZai's Avatar
LOL I don't even know what you're talking about. AC Control to activate VTEC? what?
You would provide 12v+ the wire that goes to the VTEC solenoid. Nothing else is going to activate VTEC.
With an OBD0 to OBD1 ECU Conversion Harness you'll have a pigtail of sensors that need to be connected, this will have VTEC, VTEC Oil Pressure, 4-Wire O2 sensor, Knock Sensor and IAB(gsr) wiring. You'll run these seperately anyhow.
See the Rywire Conversion packages. http://www.rywire.com
We can tap your ECU Jumper with your VAFC pigtail if you would like us to.
Old Sep 14, 2005 | 07:50 PM
ef8 h0!'s Avatar
Default Re: rhd crx ecu ? need help (NikoZai)
wait wait wait. you run boost on an obd0? hum i thought u could.
Old Sep 14, 2005 | 07:55 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">LOL I don't even know what you're talking about. AC Control to activate VTEC? what?
Using AC to activate VTEC sounds like a task, as you would need to reach over and hit the AC button each time you want vtec. I myself would prefer automatic activation through the ECU.
The AC button is versatile for tons of things though, since all it does is send an on/off signal to the ECU. My friends and I talked of using it for launch control, or even better, putting the compressor back on and actually making the AC work .
Old Sep 14, 2005 | 08:44 PM
sorry if I confused you guys as this is my first time asking a question.I no longer have the DX wiring from the seats forward it is now the jdm sir wiring in its place so i was able to keep the power windows, and the climate controle easily. The car is wired just like a jdm sir crx NOT a dx/si/hf crx. The vtec wiring is already there. And for the ac control read xenocrons page for VTEC with turboedit and you get where i got the one-wire vtec from. Now back to my first question with what i just said can someone help me find a good fuel managment? sorry again
Old Sep 14, 2005 | 08:49 PM
Default Re: rhd crx ecu ? need help (ef8 h0!)
EF8 HO i was talking about the ecu not the car or year. u can't use pw0/pr3 ecu for boost from what i found.
Old Sep 14, 2005 | 08:57 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91jdmhatchback &raquo;</TD></TR><TR><TD CLASS="quote">u can't use pw0/pr3 ecu for boost from what i found.</TD></TR></TABLE>
Go to http://www.pgmfi.org and research BRE. PR3 with boost is supported.
Old Sep 14, 2005 | 09:05 PM
Default Re: rhd crx ecu ? need help (Jim Truett)
thanks alot for clearing that up it is just what i read about the boost issue.
Old Sep 15, 2005 | 04:44 AM
drdisco69's Avatar
Default Re: rhd crx ecu ? need help (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">Using AC to activate VTEC sounds like a task, as you would need to reach over and hit the AC button each time you want vtec. I myself would prefer automatic activation through the ECU.
Well I have great news for you! First, the stock code has been rewritten to use the AC clutch output to *automatically* control the VTEC solenoid, just like a VTEC ecu would. TurboEdit allows you to do this, or use the torque convertor lockup line on the PS9 ecu. It, and most other rom editors, also allow you to add launch control, without pressing buttons. The ecu looks at the vehicle speed. If it is less than a user set value, for instance 8mph, it sets the rev limiter at the launch rpm you set, such as 5500rpm. As soon as the car gets above the set speed, the regular redline is used.
Knowledge is power: http://www.pgmfi.org
Old Sep 15, 2006 | 01:42 PM
LankorDie's Avatar
Loved
Community Favorite
Default Re: rhd crx ecu ? need help (drdisco69)
u should builda rhd car dudee
89 z6 civc
14
Nov 3, 2005 07:11 PM
twin-turbo
Oct 25, 2005 10:24 AM
GroundZer0 336
10
Aug 10, 2005 12:20 PM
turbotime.
Apr 23, 2003 10:04 AM
Acura_I-RS
Mar 2, 2003 05:11 PM
