d15 bogging while suddenly accelerating(not cables)searched
Old Sep 14, 2005 | 09:01 AM
dnbruut's Avatar
Default d15 bogging while suddenly accelerating(not cables)searched
my girlfriend has got a 94 civic with a d15engine.problem is: 9 out of 10 times everything is normal but sometimes when you push the throttle (from 0 to half way) it'll give some hessitation(head almost to the dash and then its normal) i have already replaced the spark cables and plugs.
anny thoughts?
thanks!
Old Sep 14, 2005 | 09:57 AM
sohc_boy's Avatar
Default Re: d15 bogging while suddenly accelerating(not cables)searched (dnbruut)
is it throwing any cel's?
Old Sep 14, 2005 | 10:14 AM
dnbruut's Avatar
Default Re: d15 bogging while suddenly accelerating(not cables)searched (sohc_boy)
nope!
Old Sep 14, 2005 | 10:18 AM
CaliforniaHighwayPatrol's Avatar
If it delays I would say the fuel injectors, that was my old problem
Old Sep 14, 2005 | 10:35 AM
dnbruut's Avatar
Default Re: (VTEC-Power)
its like a 1/10th of a second "misfire"
like a short but hard tap on the brakes.
Old Sep 14, 2005 | 10:36 AM
CAT clogged?
Old Sep 14, 2005 | 10:47 AM
dnbruut's Avatar
why would a clogged cat cause a sudden hesitation when going from zero to half throttle(sometimes)?
Old Sep 14, 2005 | 10:49 AM
tap your CAT with a pen
Old Sep 14, 2005 | 11:06 AM
dnbruut's Avatar
how do you meen tap it with a pen?and why would it couse the engine to make that "misfire"feeling?
i have driven a few cars with cloged cats but it only killed power or it wouldn,t rev past 4k or something and the wouldn't pass smog tests but i never had a car that bogged like this that i couldn't fix with some sparkplug cables.
Old Sep 14, 2005 | 12:18 PM
Im not saying that is the problem for sure, but it could be helping it. Obviously if it is misfiring it has to do with the plugs, wires, ditributor, coil, etc...
Old Sep 14, 2005 | 12:27 PM
dnbruut's Avatar
thanks but i dont think its the cat and i don't want to replace everything untill i know what the problem is.
ok i'll change the quistion:
annybody ever had any experience with this problem?
annybody ever had misfire(sometimes) on a 80kmile stock engine becouse of bad coil/dizzy?
Old Sep 14, 2005 | 07:31 PM
sohc_boy's Avatar
Default Re: (dnbruut)
actually i'm having the same problem. under part throttle the car will bog bad, if i back of the gas and get back on it's fine. it doesn't do it all the time either, it did this to me last year and mysteriously fixed itself. now the problem is back, i already changed the cap, rotor and plugs. i haven't actually gotten a chance to really try and fix it but its getting increasingly annoying. any idea's would be a big help. i really think its ignition related not fuel related and i'm starting to think it might be a bad ignitor or coil.
Old Sep 15, 2005 | 02:59 AM
dnbruut's Avatar
Default Re: (sohc_boy)
we have different problems! mine only does it somtimes when i push the throttle for 1/10th of a second! think your problem ae the sparkcables. that happens a lot!
Old Sep 15, 2005 | 12:02 PM
dnbruut's Avatar
annybody?
Old Sep 16, 2005 | 07:38 AM
Kaeolian's Avatar
Sounds like a distributor problem when mine went up untill about half throttle is was flat n then would suddenly go to almost full throttle, my local tuning garage said that hondas have a problem with the distributor bearing cracking the casing... dunno how true this is but thats was my problem hope that helps
Old Sep 16, 2005 | 08:12 AM
dnbruut's Avatar
Default Re: (Kaeolian)
its the first time i heard this but i'm not saying it isn't true. i know the distributor bearing is known for breaking but i can't see the logic in it throwing of timing.
thanks
Old Sep 21, 2005 | 03:55 AM
sohc_boy's Avatar
any luck? i'm still having the same problem and i already changed the wires as well so that's not it. i was thinking possibly a bad coil or ignitor, any idea's guys?
Old Sep 21, 2005 | 07:10 AM
dirtyracer's Avatar
have the same problem with mine. except that it only starts to happen when i really get on it or when barely push the gas, like i'm edging up at a light, yours might be a little different. i was told to check sparkplugs and the fuel filter.
Old Sep 21, 2005 | 07:14 AM
JDM-97CX's Avatar
Default Re: (JDM VTACK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM VTACK &raquo;</TD></TR><TR><TD CLASS="quote">If it delays I would say the fuel injectors, that was my old problem</TD></TR></TABLE>
Doubt it.
Check the TPS.
I can't believe all of the things that people say it is. All of those things would not cause an intermitent problem like is occuring is his car.
Old Sep 21, 2005 | 07:18 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: (JDM-97CX)
If it started happening recently, and only at lower rpms, then it could be the coil in the dizzy going bad.
Old Sep 21, 2005 | 07:19 AM
JDM-97CX's Avatar
Default Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">If it started happening recently, and only at lower rpms, then it could be the coil in the dizzy going bad.</TD></TR></TABLE>
But it would happen all the time. Not once in a while.
Old Sep 21, 2005 | 07:20 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">But it would happen all the time. Not once in a while.</TD></TR></TABLE>Yeah. But his is 9/10, close enough to all the time for me.
It's def something to check out.
Old Sep 21, 2005 | 07:21 AM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Yeah. But his is 9/10, close enough to all the time for me.</TD></TR></TABLE>
Go back and read again. He said 9 out of 10 times it is perfectly normal.
Old Sep 21, 2005 | 07:23 AM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">Go back and read again. He said 9 out of 10 times it is perfectly normal.</TD></TR></TABLE>Oops.
Old Sep 21, 2005 | 10:22 AM
sohc_boy's Avatar
Doubt it.
Check the TPS.
I can't believe all of the things that people say it is. All of those things would not cause an intermitent problem like is occuring is his car. </TD></TR></TABLE>
if it were the tps wouldn't it throw a code?
