Problem with tranny install...need help ASAP
Old Sep 14, 2005 | 06:07 AM
dynamyks's Avatar
Default Problem with tranny install...need help ASAP
okay i just changed my clutch and now i cant get the tranny back on!!...
everything seems fine when we put it up, but when we start bolting it, it just wont line up right..we've taken it off and on atleast 10 times
has anyone had the same problem?....any suggestions why the tranny wont line up right??....
Old Sep 14, 2005 | 06:10 AM
BlackLudeSi's Avatar
Default Re: Problem with tranny install...need help ASAP (dynamyks)
make sure the clutch and pressure plate are seated fully and if there are any dowels get them lined up to. I had a problem once with a D series motor doing the same thing, we had to pull the shift arm up on the tranny to get it to seat, maybe try that?
Old Sep 14, 2005 | 02:38 PM
dynamyks's Avatar
Default Re: Problem with tranny install...need help ASAP (BlackLudeSi)
thanks bro....any one else got any suggestions??
Old Sep 14, 2005 | 07:02 PM
Sam92Teg's Avatar
Mine didn't seem to want to mate to the block either, but I just started a couple bolts up top and two underneath alittle at a time and it pulled it together nicely. Don't force anything. If I remember right, it was about a quarter inch gap that I couldn't push any farther, then I just started the bolts and crossed my fingers. Everything went well and is perfect now.
Old Sep 14, 2005 | 10:04 PM
adobospoon's Avatar
bump
Old Sep 15, 2005 | 01:08 AM
Takumi Fujiwara's Avatar
Default Re: Problem with tranny install...need help ASAP (adobospoon)
If you tried it that many times, it's possible that you may have shifted the clutch plate around... If this is the case, loosen the pressure plate bolts, put the alignment tool back in, retighten the bolts and see if it'll line up with the spline in the tranny...
Old Sep 15, 2005 | 08:29 AM
knomexx's Avatar
Default Re: Problem with tranny install...need help ASAP (Takumi Fujiwara)
make sure they gave you the correct clutch. compare the clutch tool with the input shaft on the transmission.
Old Sep 15, 2005 | 08:45 AM
SilverDc2's Avatar
Default Re: Problem with tranny install...need help ASAP (knomexx)
either
1. they gave you the wrong clutch, cable and hydro are different,
2. you moved the clutch around and not wont go back in..
you should get someone to help you install it, with 1 person its difficult.
Old Sep 15, 2005 | 09:32 AM
SilverDc2's Avatar
Default Re: Problem with tranny install...need help ASAP (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">
Thats not always the case 90-91 integra input shafts are a little smaller than 92-01, thats the only diff.</TD></TR></TABLE>
Thats why I put "either"
but if the input shaft is different, its not gonna go in.
Old Sep 15, 2005 | 03:03 PM
dynamyks's Avatar
Default Re: Problem with tranny install...need help ASAP (SilverDc2)
okay...so i compared both my new clutch to my old one and determined they are the same...even went down to an autozone to make sure...but still no luck
i kno it absolutely has to be perfect, but this is frustrating....i guess all i can do is keep at
thanks for the feedback...any more suggestion or advice would be much appreciated
jdm.fanatic
Sep 13, 2010 12:40 PM
UCNTCME
12
Nov 25, 2009 08:10 AM
ftrms
Mar 5, 2009 06:23 AM
lsturbo*
Mar 3, 2008 02:02 PM
si0385.
Dec 23, 2005 05:13 PM
