PCV (catch can) line route?
Old Sep 13, 2005 | 10:05 PM
nello a.'s Avatar
Default PCV (catch can) line route?
air comes in from the line coming off the intake(not manifold),through the engine, out the other side through the pcv valve, and into the intake manifold, then burned up turned to sludge/whatever. is the engine sucking the air through from the intake manifold, or is the engine pushing it out? both?? pages missing from old 88-91 crx manual? tried search function? if anyone has time, please explain. i want to install catch can? picture of a b16 with air direction arrows would be sufficient for my fried-31-year-old-brain. thanks
Old Sep 13, 2005 | 10:16 PM
nub.96ek's Avatar
Default Re: PCV (catch can) line route? (nello a.)
Run a line from the breather tank on the back of the block to the the can... that's the "out" line from the motor.
Then run a line from the tank to the pcv or manifold... that's the "in" line to the motor.
Hope this helps...
justYncredible
Jul 16, 2012 10:22 AM
E.Honda
Jan 20, 2006 02:12 PM
folta2169
Apr 25, 2005 08:36 PM
