Dilemma
Old Sep 13, 2005 | 09:55 PM
CompanyFlow's Avatar
Default Dilemma
I have an OBD I LS motor in my 97 GSR. I cant smog the car and I constantly throw a CEL. Is there a way to remedy this (convert motor to obdII?) without having to swap out the motor?
Old Sep 13, 2005 | 11:29 PM
Spectrum24x's Avatar
Default Re: Dilemma (CompanyFlow)
just a question, why an ls motor in a gsr?
Old Sep 13, 2005 | 11:34 PM
White GSR '01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">I have an OBD I LS motor in my 97 GSR. I cant smog the car and I constantly throw a CEL. Is there a way to remedy this (convert motor to obdII?) without having to swap out the motor?</TD></TR></TABLE>
Go to autozone and find out WHY the CEL is on. They read ECU codes for free. Then you will know what the actual problem is.
AND WHY DO YOU HAVE A GSR WITH AN LS IN IT???!!!
Old Sep 14, 2005 | 03:17 PM
Default Re: Dilemma (White GSR '01)
Theft, and I wasnt covered by insurance, so I picked up a motor from my yard and plopped it in. It throws a CEL because of using an OBDI ecu in an OBDII car.
Old Sep 14, 2005 | 05:04 PM
Default Re: Dilemma (Subawho)
That doesnt solve my problem. I still wont be able to smog it. Thats why I want to either connvert the motor (if possible) to OBDII or the cars wiring to OBDI
Old Sep 14, 2005 | 08:07 PM
You said you have a conersion harness, and that wont work. It would still be an OBDI motor and it would fail smog. I need a way to convert the actual motor to OBDI, not a conversion harness.
Old Sep 14, 2005 | 08:14 PM
Kendall's Avatar
I believe you have some of your information a little mixed up. It's not throwing a code because of an OBD-1 ECU in an OBD-2 car, in fact without a conversion harness there's no way to even put the OBD-1 ECU in the car, and when you do get it in there it's going to be less likely to throw codes (the beauty of OBD-1). If you do indeed have an OBD-1 computer in it, it's coding due to a component failure or wiring issue of some sort. In addition, in Cali it isn't legal to put an older motor in a newer car anyway so I wouldn't be fooling around with trying to make this one work, I'd be finding a newer motor.
Old Sep 14, 2005 | 09:07 PM
Default Re: (Kendall)
Well I know I cant put an older motor in there, im just looking to alternatives to having to buy another one. Its far too costly to swap in another motor of the same thing, so Im trying my damndest to not have to. I do have an OBDI ecu running, and it has a plug just hanging out of it.
Krucial_Ek9
Apr 16, 2008 07:54 AM
jikespingleton
Dec 2, 2006 04:18 PM
GR_DC2
Dec 26, 2005 05:53 AM
GSRtypeR
Jan 5, 2004 09:16 PM
rjardy
Nov 18, 2003 08:02 PM
