swap a fully built motor FROM car to car
Old Sep 13, 2005 | 09:40 PM
immikejones's Avatar
Default swap a fully built motor FROM car to car
i have two running cars. one is a 96ex and the other is a 95eg with b18c. i want to swap the motor out one to the other.
SO, im putting the 96ex swap into a 95 hatch and a obd1 swap into a 96. PLEASE I NEED TO WHAT I NEED TO GET BOTH CARS RUNNING AFTER THE SWAP.
Old Sep 13, 2005 | 10:16 PM
fmrprojects's Avatar
you need to change the computer, engine mounts, and wiring harness. the b18c into the civic you need 99-00 civic si engine mounts. you could use the wiring harness from the single cam and swap out dizzy plugs and use a jumper. the 96b single going into the eg you could use the gsr wiring harness and change the dizzy plugs but you have to run a obd-1 p28 ecu
Old Sep 13, 2005 | 11:22 PM
Default Re: swap a fully built motor FROM car to car (immikejones)
so, to put the obd1 gsr swap from the 95 civic into the 96ex i will need: obd2 dohc vtec distrubutor and 99 si mounts? what about injectors?
the sohc vtec swap from the 96 ex into the 95 civic, what will i have to do to get that in? obd1 distrubutor and 92-95 sohc mounts?
let me know
Old Sep 14, 2005 | 07:54 PM
bump. i need a for sure answer so i can buy parts if i need them. if i dont need parts, this project will start asap
kennybintegra
13
Nov 24, 2019 09:22 PM
crappyshifting
Aug 19, 2013 11:49 PM
defie420
17
May 31, 2009 08:36 PM
CiviCVuE
Mar 9, 2007 03:33 AM
