Clutch suggestions, D16 300+whp.
My car came with a Spec Stage 2 Clutch, what junk, it was fine for when the car was stock, but after i built the motor, it lasted 800 miles and slipped a little until then. I want something i can rely on, i've heard horrible things about Spec, so give me some suggestions.
Thanks!
Thanks!
u were in the same situation as me!
i had a spec stage 2 clutch.... overheated alot and slipped on the dyno past 200 lbs tq...
now i have a competition stage 4 clutch on my d series and i have 300 whp 271 lbs tq...
and it works well and is cheap!
All i can find that'll support my modifications (and it's getting close) is a full race clutch from ACT.
"ACT CLUTCH KIT: CIVIC 92-02 & DEL SOL 93-95 (SOHC)padAdvanced Clutch Technology Clutch Kit for Honda Civic 92-02 SOHC and Del Sol 93-95 SOHC 212MM (Complete Kit comes with xtreme pressure plate, 6-pad race disc, release bearing, pilot bearing & alignment tool). This clutch offers 350LBS of Torque. Note: not recommended for street use due to harsh engagement.
pad
ACT-HC5-XTR6padMSRP: $485.30padOur price: $388.24pad"
pad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">All i can find that'll support my modifications (and it's getting close) is a full race clutch from ACT.
pad
ACT-HC5-XTR6padMSRP: $485.30padOur price: $388.24pad"</TD></TR></TABLE>
http://www.competitionclutch.c...ble=1
im running stage 4 sprung and it cost me $350 only
pad
http://www.competitionclutch.c...SI%21
You bought from them and it's no **** $350 shipped for the entire kit? Clutch, disc, throw-out bearing, etc.? I figure i'll go with Stage 5, it's the same price as Stage 4...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">http://www.competitionclutch.c...SI%21
You bought from them and it's no **** $350 shipped for the entire kit? Clutch, disc, throw-out bearing, etc.? I figure i'll go with Stage 5, it's the same price as Stage 4...</TD></TR></TABLE>
don't over-do it on a clutch... get what you need...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">That <U>is</U> what i need.
I'm going for 300whp which on my engine will be around 330 at the crank and around 310ft/lbs.</TD></TR></TABLE>
i doubt you'll hit such high torque numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">300 whp 271 lbs tq...</TD></TR></TABLE>
Account for a 30hp/tq drivetrain loss (i don't know or really care what it actually is), it comes to around 300-310.
This clutch has a capasity of 250-350% over stock, which is 265-371, i'm in the middle of it's capasity.
hi, i dont want to jack your thread but i'm in the same dillemma...looking for a clutch that will do me well but i'm also looking for a clutch that has a hard pedal pressure...such as the rps clutch pedal pressure that my uncle has on his car...if anyone can recommend a clutch that is reliable and stable to handle the 300+whp your support will greatly be appreciated...thanks...
pjr710
Jul 23, 2008 09:53 AM
99V-unit
Apr 22, 2008 05:13 PM
