Ek hatch 5 lug toe in problem
i have a hatch and i just put five lug on there and on my driver side rear wheel my toe seems to be off i know this is a common problem for ek hatches.. i went to an alingment place and they said my trailing might be bent.. when the trailing arm was off the car it didn't seen bent. while lookin under the car the tire is almost touching the trailing arm.. and if i was to get a toe kit would it move the trailing closer to the tire or farther away and at the same time fixing the toe specs being off..
i need advice should i..
swap the hub to my old trailing arm.?
Get a toe kit??
thanks
Get a toe kit??
thanks
As long as I dont have to take out any more Metal Gears
It sucks that u cant really tell if the trailing arm is bent until its on the car. I dont think a toe kit would do anything. Swapping the hub and the rest of its components to another trailing arm would be the most cost effective solution. Maybe u should contact the guy u bought it from and bitch at him until he gives u something to compensate
its not too hard, but u may have to rent some special tools, like a slide hammer. Auto zone, or kragen have tools u can borrow for free. I have swapped out my trailing arms for integra's and i was lucky mine werent bent. I have never swapped out the hubs, but i have seen threads here on HT of ppl that have done it before. Do a search and see what u can find.
thanks guys i swapped out the trailling arms and swicthed the hubs and went to the alignment place they didnt' have time to do it buy said that it looks 100x better.. and after i looked at the type r trailing arm it looked bent..
StupidSlowRSX
Jan 10, 2005 10:46 AM
the_illest_soldier
35
Jan 5, 2005 01:24 AM
SPOONfdEK
Aug 15, 2003 09:24 PM
