obd2b to obd1 wiring problems
Old Sep 13, 2005 | 08:03 PM
hifi_civic's Avatar
Default obd2b to obd1 wiring problems
i have a 99 civic dx. its obd2b and the b16 motor im putting in is obd1. i ripped out my engine harness, and got an obd1 wire harness from a 95 civic ex. i got a big problem though. i still have one ecu plug that goes to the fuse box under the hood. the ecu plug that used to go into my obd2b ecu doesnt fit in the p28. how will i make this plug fit into my p28 ecu?
any help is greatly appreciated. thanks in advance.
roger
Old Sep 13, 2005 | 11:15 PM
NikoZai's Avatar
Default Re: obd2b to obd1 wiring problems (hifi_civic)
NO
You need to use your 99 Civic DX wiring... Put it back please
You can keep your OBD2 injectors, use those on your B16, yes they fit, they're exactly the same.
Next, this is what you need to do:
- 3-wire converted to 2-wire EACV modification
- ECU Jumper from OBD2b to OBD1 - http://www.jkobd.com/2bto1.htm
- Knock sensor (if P30 ECU)
- VTEC
- VTEC Oil pressure
- Distributor Jumper from OBD2b to OBD1 http://www.rywire.com/dizadapters.shtml
We can provide you with a subharness for all your sensors for $45.
Give us a call, the # is on the website. http://www.rywire.com
95 iteg
10
Jun 3, 2013 11:36 AM
dkler
19
Mar 13, 2010 10:53 PM
E.
Apr 21, 2008 08:40 AM
Teal95Coupe
Aug 16, 2004 07:53 PM
pagong
Sep 27, 2001 07:40 PM
