Tranny Question??????
I have a 90 civic HB Si, the shop i bought the car from had swapped in a sohc zc motor and it looks as if it is a Si transmission. How can you tell what kind of transmission I have. There is a number plate on the tranny that starts with L3-...... not real sure what that means, does anyone know if I call Honda and tell them that number they could find out what kind of tranny I have. Thanks
All 88-91 civic/crx transmissions were L3s. That is why they are so hard to tell apart. Someone posted a discussion on how to tell the difference. Anyone have a link??
Yeah cause I bought an axle seal for a Si tranny but its definitely not fitting and i called honda and its the right part for an Si tranny, so not sure what to do I need an axle seal cause my old one is torn up.
uh there are differences in the trannys and there is a different # like p3000 and some other ones but there are differneces as for where it is its on the casting on the side of the tranny i think mista bone knows i think
Hey mista bone do you know how to tell what kind of tranny i have in my car? Its a 5-speed so that probably eliminates some of the tranny's. Any ideas?
yea i just got a tranny. the only codes i can pull off it are PL3, SL3, 100?
it has a stamp near where the starter mounts. that says PL3
theres a sticker that looks like a serial number that says SL3-*******
and on the split circle code area. the left little one says 2|15, the right larger one says *|100 i put a * cuz i cant read what the top half of the circle says on the larger one.
i haven't cleaned it completely yet. but those are the stamps/stickers i have found on it. he says it will bolt right onto a b series motor. but i have no clue. i bought it for a replacement for my b16a S1 tranny.
i'll clean it completely after work today. and see if i can pull other codes off.
[Modified by escocrx, 1:37 PM 2/28/2002]
you can thank mr bone and eraser for this. http://www.d16a.com/d_series_trannys.htm
ZippyZivic
16
Feb 13, 2007 11:39 AM
groundedcivic91
Jul 13, 2004 08:03 PM
