Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Are these metal cracks serious? Repairable?
Old Sep 13, 2005 | 07:43 PM
Sterndotstern's Avatar
Default Are these metal cracks serious? Repairable?
I bought my race car used, and when I got it home I noticed the right side had taken a bit of a crunch in the hands of a previous owner. The (replacement) door doesn't fit quite right, and there are these cracks running along the bottom and back of the door frame. Do the cracks have any appreciable effect on the structural rigidity of the unibody?
If so, are the cracks repairable? I was thinking about some serious welding and grinding to try to close them, but the gap seems pretty big. Is it even worth worrying about?
Jon, who still loves his car, even if it does have some laugh lines...
Old Sep 13, 2005 | 08:06 PM
civicrr's Avatar
Default Re: Are these metal cracks serious? Repairable? (Sterndotstern)
Those cracks will definitely affect the ridgidity of the car. That section is considered the 'frame rail' of the car. How much it make a diff. depends on the quality of the cage. I would clean it up & weld those areas. Be careful & really take your time. You don't want to overheat the metal as that will cause it to be weakened.
Old Sep 13, 2005 | 08:16 PM
Track rat's Avatar
Default Re: Are these metal cracks serious? Repairable? (civicrr)
Some of that looks like Bondo, especially around the door keeper. Looks like that rocker has been replaced and or repaired before.
Old Sep 14, 2005 | 07:08 AM
Formula Racing's Avatar
Default Re: Are these metal cracks serious? Repairable? (Track rat)
MIG weld the seams after grinding it down and assessing the damage!
Old Sep 14, 2005 | 07:11 AM
JDM Factor's Avatar
I'd definetly try cleaning that up a bit, has anyone tried filling hollow spots in the frame with foam? Maybe that will help the rigidity
Old Sep 14, 2005 | 07:17 AM
JeffS's Avatar
Default Re: (JDM Factor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Factor &raquo;</TD></TR><TR><TD CLASS="quote">I'd definetly try cleaning that up a bit, has anyone tried filling hollow spots in the frame with foam? Maybe that will help the rigidity</TD></TR></TABLE>
Maybe, but certainly wouldn't help the legality...
Would there be an issue iwth welding this area? I suppose it would fall into the repair category, but if someone wanted to make a big deal out of it?
Old Sep 14, 2005 | 08:19 AM
civicrr's Avatar
Default Re: (JeffS)
A repair won't be an issue for NASA racing. I don't think it will be for SCCA. Any rational preson will realize it is a repair & not a 'extra ....' to the car. I guess to CYA, you should take pictures of before & after & keep with the logbook.
Old Sep 14, 2005 | 08:30 AM
HapaHaole's Avatar
Default Re: (civicrr)
thats a lot of bondo! must be hiding a wrinkly panel under there.
Old Sep 14, 2005 | 05:14 PM
Default Re: (BSME)
Thanks for the responses all. Looks like I've got my work cut out for me. Maybe the whole "used racecar" thing wasn't all it was cracked up to be... AHAHAHA OH I KILL ME.
Old Sep 14, 2005 | 05:37 PM
Sliced Beard's Avatar
Default Re: (Sterndotstern)
j0o are one crazy <U>crack</U> head
Old Sep 16, 2005 | 04:28 AM
ekek888's Avatar
the cracks are repairable but not easy or cheap. your car is not straight. cut the roll bar and have the body aligned. the new door should fit after the repair.
Old Sep 17, 2005 | 10:11 AM
rice r0cket's Avatar
Default Re: Are these metal cracks serious? Repairable? (ekek888)
Damn, yank that cage out and find a new tub.
wdissident
Sep 22, 2008 10:23 AM
xanatos
Honda Civic (2006 - 2015)
10
Apr 3, 2007 03:14 PM
Filliam H. Muffman
84
Dec 29, 2004 05:28 PM
KiDSoL
74
Feb 16, 2004 08:30 AM
R-Adrenaline
Aug 21, 2001 09:46 AM
