b16 into 95 dx swap, questions
Old Sep 13, 2005 | 07:21 PM
CantGetRich's Avatar
Default b16 into 95 dx swap, questions
what wiring harness will i need to swap a 1st gen b16 with b18c1 cams into a 95 dx. I will also have a 2nd gen b16 tranny, will i need to buy motor mounts? Is a 95 dx cable or hydrolic? I need some help.
Old Sep 13, 2005 | 07:28 PM
VTECVillain's Avatar
Default Re: b16 into 95 dx swap, questions (CantGetRich)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CantGetRich &raquo;</TD></TR><TR><TD CLASS="quote">what wiring harness will i need to swap a 1st gen b16 with b18c1 cams into a 95 dx.</TD></TR></TABLE>
Easiest solution is a 92-95 Civic EX or Si harness for best plug and play. You can also reuse your stock harness and add the necessary wiring. Regardless of which harness you choose, you will still have to add/mod wiring on the chassis side harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CantGetRich &raquo;</TD></TR><TR><TD CLASS="quote">I will also have a 2nd gen b16 tranny, will i need to buy motor mounts? Is a 95 dx cable or hydrolic? I need some help.</TD></TR></TABLE>
The second gen B16 tranny as well as your stock DX tranny are both hydraulic operated. You can reuse your stock upper tranny mount on the B16 tranny. You will need a 94-01 Integra front lower tranny dampening mount though.
Old Sep 13, 2005 | 07:34 PM
Default Re: b16 into 95 dx swap, questions (American Deathray)
what about the ecu? Which one should i get, one for a 1st gen or a 2nd gen?
Old Sep 13, 2005 | 07:35 PM
will i need to buy motor mounts? Or will they match up?
Old Sep 13, 2005 | 07:37 PM
You don't want the 1st gen B16 PR3/PW0 since it's OBD0 and will not plug into your ECU plugs without an adaptor harness and even then your back-dating. You'll want to get a OBD1 P30 (2nd gen B16/Del Sol VTEC) or a chipped P28.
Old Sep 13, 2005 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CantGetRich &raquo;</TD></TR><TR><TD CLASS="quote">will i need to buy motor mounts? Or will they match up?</TD></TR></TABLE>
Swapping a B series in an EG only requires a mix of OEM mounts. You'll need a 94-01 Integra driver's side bracket and mount and a rear bracket as well. Reuse your stock upper tranny mount then get a 94-01 Integra front lower tranny mount. You'll need a Del Sol VTEC A/C bracket if you want to retain A/C or any 94-01 Integra A/C bracket if you aren't using the A/C.
what about motor mounts?
Old Sep 14, 2005 | 01:27 PM
1fastvik's Avatar
Use your stock civic trans mount and integra rear "T" bracket and driverside mount that's all
justin1785
Jul 2, 2010 06:59 AM
nurvcom..
Dec 8, 2005 11:00 AM
AsR CiviC
May 16, 2003 12:41 AM
jumpmann23
Jan 3, 2003 01:33 PM
