I NEED HELP PLEASE!!!
Old Sep 13, 2005 | 05:42 PM
USMCDevilDog's Avatar
Default I NEED HELP PLEASE!!!
Hurrican Katrina flooded my 97 Honda Civic DX. Where is the computer located at on that model; I had about 3-4 inches of water on the inside
Old Sep 13, 2005 | 05:44 PM
johnnylaw's Avatar
Default Re: I NEED HELP PLEASE!!! (USMCDevilDog)
it should be on the passenger side, right in front of the door. pull the carpet up in that area and you cant miss it.
Old Sep 13, 2005 | 05:45 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Ouch that sucks, its behind the carpet on the passanger side kick panel, probably only about an inch under water.
Default Re: I NEED HELP PLEASE!!! (gsrturbojohn)
So i guess my car is fucked huh?
Old Sep 13, 2005 | 05:49 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USMCDevilDog &raquo;</TD></TR><TR><TD CLASS="quote">So i guess my car is f*cked huh? </TD></TR></TABLE>
Not necessarily. Remove the ECU from the car, open the cover, and allow it to thoroughly dry out. They reinstall it and see if you experience any problems. Even if you discover that the ECU is indeed damaged, a replacement will not be an exceptionally expensive item to source.
Old Sep 13, 2005 | 05:53 PM
Default Re: I NEED HELP PLEASE!!! (Padawan)
it has been sitting in my hot *** garage for about a week now, i am at a friends house. All the water was receeded from the car when i saw it a week ago, and we can only go into the city at certain times. Do u think the car would be alright to try and start?
Old Sep 13, 2005 | 05:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USMCDevilDog &raquo;</TD></TR><TR><TD CLASS="quote">Do u think the car would be alright to try and start?</TD></TR></TABLE>No not without..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Remove the ECU from the car, open the cover, and allow it to thoroughly dry out. They reinstall it and see if you experience any problems. Even if you discover that the ECU is indeed damaged, a replacement will not be an exceptionally expensive item to source. </TD></TR></TABLE>
Otherwise you WILL fry the ECU if you try and start the car with everything in there all wet. It could also create other electrical issues in the car itself.
Old Sep 13, 2005 | 05:57 PM
Padawan's Avatar
Darth ModerVader
I honestly would not try to start it until the ECU had been removed and thoroughly dried out. Even a small amount of remaining moisture could potentially cause a damaging short.
Old Sep 13, 2005 | 06:04 PM
k guys thanks for all of yalls help n Godbless
Funanin
Dec 28, 2007 10:19 AM
Ga0887
Feb 25, 2007 02:01 PM
Moemers
Honda S2000
Jul 11, 2005 12:59 PM
hypedlunatic
Apr 4, 2004 05:58 PM
sharkey65a
Jul 1, 2003 04:32 PM
