HELP~!!! please everyone
Old Feb 27, 2002 | 05:45 PM
TaboR's Avatar
New User
Default HELP~!!! please everyone
dont know what happened to my transmission~ 1st gear starting gran
some times when rolling start..... i never miss shifted my R and i babied
my R. i have the spoon flywheel and clutch sets and i am using KAAZ 80w-90
LSD transmission oil. these are the only transmission related modification that
i have. any body please help.....
Old Feb 27, 2002 | 05:55 PM
STOLEN - ITR 98-0652's Avatar
Default Re: HELP~!!! please everyone (FreddyR)
That's some hella thick tranny oil... considering I've heard the Honda MTF is about 30 weight.
Sounds like sychros - a known weak link, eh? Good luck getting it warrantied with that Spoon ***** - most likely it "contributed to the part failure".
You've been warned.
Old Feb 27, 2002 | 06:01 PM
SoCal ITR's Avatar
Default Re: HELP~!!! please everyone (ITR 98-0652)
If possible, switch it back to stock before you take it in.
Old Feb 27, 2002 | 06:56 PM
Bbasso's Avatar
ya ya dump that aftermarket stuff before you bring to a dealer, contributed to failure of transmission.
good luck!
Old Feb 27, 2002 | 07:03 PM
Austin's Avatar
Remove the KAAZ fluid!!! which is not designed to be run with a stock differential, switch back to the honda stock fluid and your problems should be cured...if not then take it to the dealer.
Austin
Old Feb 27, 2002 | 07:05 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: HELP~!!! please everyone (Bbasso)
good luck!
Just an FYI. Even if you remove the aftermarket pieces, it will be *OBVIOUS* that the tranny has been removed.
Old Feb 28, 2002 | 07:12 PM
TaboR's Avatar
New User
huuu~~ just got under my R and swap the oil back to the Honda MTL
and now every thing is back like it used to be~ its now all smooth~ ^_^
thanks u all~
Old Feb 28, 2002 | 08:12 PM
Austin's Avatar
thanks u all~
Good, glad to hear that you fixed it.
Austin
troubleshooter
Transmission & Drivetrain
Dec 1, 2017 05:34 AM
extrah
Aug 7, 2005 05:11 AM
Vspec Sol
Apr 10, 2003 11:04 AM
seanb18c1
Feb 22, 2003 11:18 AM
Timmayeg
Nov 24, 2001 12:33 PM
