DIY head build.... difficult?
Old Sep 13, 2005 | 03:18 PM
A2_8U's Avatar
Default DIY head build.... difficult?
Im thinking about replacing cams, valves springs and retainers on a spare b16a head i have in my shed before getting a mechanic to chuck it on my b18c along with some ctr pistons.
Ill be using omni power springs/retainers, and skunk2 stage2 cams and cam gears at this stage.
Can i do the head work myself? i have no experince at all with this so would need some good 'how to' resources.
Ive searched and havnt found any 'how to's' on here, if anyones got some good links that would help itd be great.
Thanks
Old Sep 13, 2005 | 06:51 PM
Honda Sport's Avatar
very simple. all you need is a valve spring compressor. make sure you don't lose the keepers when taking everything off. all you do is compress the valve spring, take off the keepers, then the spring will come right off. put back in reverse order.
Old Sep 13, 2005 | 07:37 PM
A2_8U's Avatar
thanks for the reply.
So the spring compressor the only special tool i need? any sort will do?
Anything special i need to know about putting cams and retainers in? or is it just duno bolts, pull out the old and in with the new?
Old Sep 13, 2005 | 08:43 PM
SuperSpic's Avatar
search for BIG TEGGIE, he did a full write up on building a nice N/A LSVTEC and he had a in depth write up on how he put the head together.
*heres the link https://honda-tech.com/zerothread?id=1118097
Old Sep 13, 2005 | 08:58 PM
RyceRacerX's Avatar
Try buying a repair manual. It will show you most of it along with torque specs for the bolts and the procedure. Yeah its pretty basic hand tools, valve spring tool, torque wrench, and probably a feeler gauge.
Old Sep 13, 2005 | 09:27 PM
A2_8U's Avatar
Default Re: (RyceRacerX)
excellent thanx for that... ill have a read
crxb16a90
Jan 6, 2010 08:04 AM
racereaper7
Oct 30, 2007 01:55 PM
95GSRTT
Sep 15, 2004 07:37 PM
Anthonyl469
Mar 13, 2003 11:25 AM
TheLostOne
Dec 11, 2001 05:40 PM
