part # for ob1 b16 dissy
i need either a part number for a ob1 b16 dissy to know what car came with a ob1 b16. My dizzy went out on my jdm b16 and we cant seem to find a ob1 dizzy that bolts on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrs. PlanB »</TD></TR><TR><TD CLASS="quote">what about a 94-95 del sol vtec (b16a3), or is that obd2?</TD></TR></TABLE>
that is what we thought to, but the mounting points are in different locations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gambit- »</TD></TR><TR><TD CLASS="quote">
that is what we thought to, but the mounting points are in different locations. </TD></TR></TABLE>then td-44u is the part number that will work.
part # td-44u I know for sure is obd1, it has the white plug</TD></TR></TABLE>
white plug = non-obd.
grey plug = obd1 or 2.
distributor king lists TD-55u or TD46U for B17A and B18C1 obd1 and TD44U or TD68U for B16A3 obd1... wierd. i always thought that dizzys on B17A, B18C, and B16A OBD1 were all interchangable. I bought one on ebay that was for B18C and B16A obd1 and it worked on my old JDM B16a.
get the one from any 92-95 b-series vtec. obd1 is 92-95 and obd2 is 96+. im not sure about when they changed or if they changed to a newer obd. are you positive that you got the dizzy you needed? someone might of said that it was a Bseries and just sent you a D. if so you could hack off one of the legs and it will work, but it might leak around the o-ring. this could get you by until you come up with the right one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
distributor king lists TD-55u or TD46U for B17A and B18C1 obd1 and TD44U or TD68U for B16A3 obd1... wierd. i always thought that dizzys on B17A, B18C, and B16A OBD1 were all interchangable. I bought one on ebay that was for B18C and B16A obd1 and it worked on my old JDM B16a.</TD></TR></TABLE>
interesting
interesting
TD-44U is correct. - (TD-68 is identical really. It will also work.)
And Rywire sells them for $235 shipped!
http://www.rywire.com/obd1diz.shtml
DC2Monster
22
Oct 22, 2003 03:57 PM
