how do you bypass a knock sensor
Old Sep 13, 2005 | 11:28 AM
blacklude1993's Avatar
Default how do you bypass a knock sensor
How do i bypass my knock sensor?
My car was throwing a 23 so i replaced the knock sensor and that didnt work so i replaced the wires and clips and that didn't work. Whats up? tapped into d3 (blue/red) and it just doesnt work. i have a complete jdm h22 swap.
Old Sep 13, 2005 | 12:34 PM
steveobb4's Avatar
Default Re: how do you bypass a knock sensor (blacklude1993)
Did u use a shielded wire? Make sure you have continuity between the engine harness knock sensor connector and Ecu pin for the ks.
Old Sep 13, 2005 | 12:55 PM
IHateJDM's Avatar
Default Re: how do you bypass a knock sensor (steveobb4)
make sure the threads in the back of the block are clean too, that is a self-grounding sensor. Other than that, the only way I know of to ditch knock would be to run a chipped p28 that doesn't look for it.
Old Sep 13, 2005 | 12:59 PM
The Weather Man's Avatar
Your question was: How do I bypass my knock sensor
My Answer: I "BELIEVE" you can do it with the hondata systems.....if you want to take the easy way out.
To clear things up: I am not SURE - I think you can do it with the hondata system, but do NOT take my word for it. Do not engrave them in stone - just keep them in the back of your head.
1sikhatch
Aug 17, 2010 08:20 AM
97blacklude
Jan 31, 2009 09:56 AM
memphosfinest
Mar 13, 2008 12:48 PM
92ludeport
Jul 8, 2005 02:08 PM
evo
Mar 4, 2003 07:10 AM
