energy suspension mount inserts
I am in desperate need of motor mounts and i have heard that the energy suspension inserts are a very good value and perform well.
Can anyone back this up?
I also need a website that sells them for my car.
Any other suggestions??
Thanks for any help.
If your current mounts are in 50% good condition you can get the mounts for 45 bones on ebay(what i did). Make sure you put all 6 parts in(3 mounts), not just 4. We all know the rear is a biyatch but it only take another hour and keeps it all smooth.
Got mine from this dude, took like 3 days...
http://cgi.ebay.com/ebaymotors...ZWDVW
BUT!!! If you mounts are all torn to ****, then you need to replace then first or the inserts will flop around and not work properly either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 »</TD></TR><TR><TD CLASS="quote">If your current mounts are in 50% good condition you can get the mounts for 45 bones on ebay(what i did). Make sure you put all 6 parts in(3 mounts), not just 4. We all know the rear is a biyatch but it only take another hour and keeps it all smooth.
BUT!!! If you mounts are all torn to ****, then you need to replace then first or the inserts will flop around and not work properly either.</TD></TR></TABLE>
i just ordered some from this same dude on ebay and i am waiting for them to come in. my two lower mounts are not completely torn or disintigrated, but they are not in the best shape either, and i a hoping that they will firm up the drivetrain/engine, like everyone says they do.
i got my inserts this weekend and i installed them. they are great. i only had time to do just the bottom two, but the difference is noticeable. both of the bottom ones were nearly torn al the way through. i will be putting in the rear one this weekend even though it is gonna be a major PITA. definately worth it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRmorris »</TD></TR><TR><TD CLASS="quote">Who sells the 2 bottom mounts?
You know, one of them needs to be removed to take off the A/C belt.</TD></TR></TABLE>
you dont have to take the mount all the way off, you just need to unbolt it and unbolt the 2 bolts from the upper mount then you and pry the mount down far enough to get a belt through the gap
it wasnt as bad as i thought it was gonna be when i changed my ac belt
If I had money I would by inserts....but hey...it works the same
