injector problem
Old Sep 13, 2005 | 11:12 AM
RaysBoomBoomLude's Avatar
Default injector problem
man, I wish there was more honda\import specialist around where I live.
Anways.
My injector is stuck open it keeps spraying fuel.
I checked the wiring. there no grounds on the wires (MPFI conversion)
I took the plug from the injector 4( one that I suspect is bad ) and put it on injector 3, and it closes. so that cancles out injector wiring.
I check the Resistance of injector 4. and its at 2.57 (helms says it should be between 1- 2.5)
so that leads me to belive that the injector is stuck, that its stuck open, and a good cleaning will clean it up.
Old Sep 13, 2005 | 11:46 AM
snowseeker's Avatar
Default Re: injector problem (LaFawnduh)
Replace the injector.
Old Sep 13, 2005 | 11:56 AM
Default Re: injector problem (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Replace the injector.</TD></TR></TABLE>
I kinda dont want to do that.
If I want to get injectors, I want to get some good ones, I dont want any autozone POS, but I also dont want to get ones directly from honda. ill have to give up my first born.
Old Sep 13, 2005 | 01:43 PM
snowseeker's Avatar
Ebay is your friend.
get some stock ones for 20.00
Old Sep 13, 2005 | 02:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Ebay is your friend.
get some stock ones for 20.00</TD></TR></TABLE>
yah, or pull them from the junkyard. I can pocket injectors. hehehe
what injectors can I use???
Old Sep 13, 2005 | 05:24 PM
iTe4LIFe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LaFawnduh &raquo;</TD></TR><TR><TD CLASS="quote">yah, or pull them from the junkyard. I can pocket injectors. hehehe
what injectors can I use???</TD></TR></TABLE>
LOL im the same way to an extent..... at one time my fried said... hey will that 89 lude shift **** screw into your rex or my civic? 2 mins later he got his answer....
injectors = ebay is a good place for cheap oem replacements.... even DSMs. or your local junkyard = (especially if you pull the part yourself).
Old Sep 13, 2005 | 05:29 PM
Default Re: injector problem (islandtechengineers)
well I am going to pull the injectors my self.
Probly a **** load of them if I cant find the ones I can use.
I herd all b injectors are the same.
Ok, what cars are those? all integras up to 96? 96 they where obd1 correct?
Also, I herd about using Honda Accord injectors, and prelude injectors.
jmeyer99
Apr 30, 2008 08:03 AM
Turbo-Honda
Jun 30, 2004 09:39 PM
safe driver
Oct 1, 2003 09:36 PM
