arospeed coilovers
Old Sep 13, 2005 | 08:03 AM
sd,integ's Avatar
Default arospeed coilovers
are these type of coil overs good on integra 94-01 there selling me some for 100 bucks should i get them ,are they a smooth ride
Old Sep 13, 2005 | 08:14 AM
xteg95's Avatar
Default Re: arospeed coilovers (sd,integ)
No, buy a used set of eibach springs from ebay for $100 instead . Those arospeeds will give you a crappy ride.
Old Sep 13, 2005 | 08:42 AM
sd,integ's Avatar
Default Re: arospeed coilovers (xteg95)
how bout skunk 2 coilovers
Old Sep 13, 2005 | 08:46 AM
mafiaboy757's Avatar
skunk2 good stuff
Old Sep 13, 2005 | 08:48 AM
sd,integ's Avatar
Default Re: arospeed coilovers (mafiaboy757)
are they a bounce ride
Old Sep 13, 2005 | 08:53 AM
sd,integ's Avatar
are they a bouncy
Old Sep 13, 2005 | 08:57 AM
xteg95's Avatar
HT is anti skunk2 right now
https://honda-tech.com/zerothread?id=1356040
They do offer a good ride though. (not bouncy) I'd prefer Ground Controls though.
Old Sep 13, 2005 | 11:32 AM
2G0S0R1's Avatar
New User
arospeed sux, they have 7" springs with a very high coil/inch ratio. You want a set with 8" springs (for the front, 7" is fine in the rear) and a low coil/inch ratio.
Get some ground controls, or some cheap coilovers for $75(arospeed is fine) and replace the front springs with some eibachs for $100.
As for the skunks, they are ok also... but im pretty sure they have short springs. Although a better coil/inch ratio.
Old Sep 13, 2005 | 11:38 AM
2G0S0R1's Avatar
New User
Default Re: arospeed coilovers (2G0S0R1)
and for the record... arospeed springs bind under ~1300 lbs of pressure, along with dropzone and OMNIPOWER. I have them all and had them tested at a local shop. They all had ~3.1" of travel (CRAP, cuz of the coil/inch ratio) and had a less than advertised 420lbs/in rate.
Your car alone applies ~900lb per front spring while resting, and the other few hundred come along very easily by hitting bumps and hard cornering.
My new eibach 8" springs bind at ~1900 lbs, while offering the same 425lb spring rate. Now you do the math, hahah.
Old Sep 14, 2005 | 06:15 AM
sd,integ's Avatar
how bout some nuespeed springs, sor 60 bucks i think i could mabye get them for cheaper, but will nuespeed work as well.
Old Sep 14, 2005 | 09:21 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
My friend had Arospeed FULL coilovers on his old car, and they were junk. You can imagine what the sleeves would probable be like.
<~~ 14,000th post
Old Sep 14, 2005 | 09:26 AM
SMZ GSR's Avatar
Default Re: (PatrickGSR94)
^ Post *****
Old Sep 14, 2005 | 03:18 PM
chrisgottigsr's Avatar
i've have aerospeed coilovers and kyb shocks and struts on my teg for a year and a half and the ride is smooth and better than stock no bouncing. handling feels great
Old Sep 14, 2005 | 06:08 PM
sd,integ's Avatar
Default Re: arospeed coilovers (chrisgottigsr)
no not arospeed coilovers. but to just put the nuespeed spring and put it on like that. will it work or is the spring to long. to make it easier what if i take the the arospeed spring and replace it for the nuespeed spring but it is not a coil over spring will it still work.
Old Sep 15, 2005 | 09:06 AM
2G0S0R1's Avatar
New User
if you already have the coilover sleeves, then pay the 100 bucks and get some good coils... like some eibachs. If you are trying to use the neuspeed springs that are full springs, they will be much too long/will not work on top of coilover sleeves.
Old Sep 15, 2005 | 10:31 AM
BrooX's Avatar
Dont cheat yourself! I did that and baught adjustable coils and 4 months later my STOCK shock boot busted. Save your money and look into something like an actual suspension application such as.....Koni or Tein just to name a few. I suggest you do some research when it comes to suspension cuz you dont want to make the same mistake that i did. It will be expensive but you wont be disappointed!
jwicecold
Aug 30, 2008 09:12 AM
udarr23
Jul 14, 2005 06:33 PM
Racermech
Feb 8, 2005 05:43 AM
MooreBoost
Jul 22, 2003 09:45 AM
DragII
Jun 16, 2002 04:05 PM
