Poly-urethane engine mounts for engine swap? Should I?
Old Feb 27, 2002 | 04:44 PM
Hayate42's Avatar
Default Poly-urethane engine mounts for engine swap? Should I?
while I have the engine befor I put it in should I install a set of Poly-urethane motor mount inserts? I figure for like $35 I should just do it now while it's out. Anyone have these and have any views on the importance of them? Thanks for the input.
Dan Cole
Old Feb 27, 2002 | 04:54 PM
Kamin's Avatar
Default Re: Poly-urethane engine mounts for engine swap? Should I? (Hayate42)
well im not using them but they are supposed to increase response
but they hurt your idle/ride because the engine is connected more stabily to the chassy.
Old Feb 27, 2002 | 09:12 PM
court's Avatar
25 Year Member
Default Re: Poly-urethane engine mounts for engine swap? Should I? (KAMiN)
wether the motor is on the ground, in the air, on the boat or in the car, it doesnt make it any easier or harder to install them. im running the red rear insert- it increase's motor response, but it doesnt vibe at idle
Old Feb 28, 2002 | 05:41 AM
Hayate42's Avatar
Default Re: Poly-urethane engine mounts for engine swap? Should I? (court)
Thanks for the input guys, I guess I get them I'm not to particular about a smooth ride at all. THanks again,
Dan Cole
Old Feb 28, 2002 | 09:17 AM
RedlinedVTEC's Avatar
I've got the ES mount inserts in my car. It vibrates, but i've grown used to it. Had to ditch the change tray though that rattling change was driving me insane.
GapxGuy
May 3, 2007 03:28 PM
meno19
14
Aug 2, 2006 03:03 AM
h22 civic
May 31, 2004 02:21 PM
morepoop4u
Aug 31, 2003 10:50 AM
bearboy80
Jul 9, 2003 01:49 PM
