Where can i get the best deals on suspension, and other structural parts?
Old Sep 13, 2005 | 07:25 AM
pny1981's Avatar
Default Where can i get the best deals on suspension, and other structural parts?
I am thinking coilovers, but i do not want to go to low. I just want it to be stiffer, body wise, and not so much spring wise. The roads i drive on are crap. So where are the best deals? Oh i have a 96 rs integra.
Old Sep 13, 2005 | 08:23 AM
xteg95's Avatar
Default Re: Where can i get the best deals on suspension, and other structural parts? (pny1981)
Here are some links:
---Suspension---
https://honda-tech.com/zerothread?id=230216 – ITR Sway Bars vs. Aftermarket
https://honda-tech.com/zerothread?id=161618 – Rear Subframe Discussion
https://honda-tech.com/zerothread?id=57813 – Strut and Sway Bar Discussion
https://honda-tech.com/zerothread?id=1183184 – GC/Koni vs. Tein Flex
https://honda-tech.com/zerothread?id=1045933 – Omnipower vs. Tein SS
https://honda-tech.com/zerothread?id=1103358 – Omnipower vs. Tein Flex
https://honda-tech.com/zerothread?id=975313 – Coilovers vs. Springs
https://honda-tech.com/zerothread?id=1192976 – Ebay Coilover Discussion
https://honda-tech.com/zerothread?id=1103213 – DA Coilover Discussion
https://honda-tech.com/zerothread?id=1194211 – Shock Discussion
https://honda-tech.com/zerothread?id=1135707 – ITR Shock Discussion
https://honda-tech.com/zerothread?id=957088 – Aftermarket Springs/Stock Shocks
https://honda-tech.com/zerothread?id=1202600 – Lower Mount Discussion
https://honda-tech.com/zerothread?id=1157855 - What Coilovers? Heres 2, Omnipower vs D2 *THANKS BLACK FIRE*
How much do you want to spend, and what kind of quality are you looking for. Most will recommend going with GC coils and Koni shocks.
Check the classifieds section for deals.
Old Sep 13, 2005 | 09:54 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pny1981 &raquo;</TD></TR><TR><TD CLASS="quote">I am thinking coilovers, but i do not want to go to low. I just want it to be stiffer, body wise, and not so much spring wise. The roads i drive on are crap. So where are the best deals? Oh i have a 96 rs integra.</TD></TR></TABLE>
Stiff body weak springs? Leave the suspension stock, and seam weld the chasis. A welder would be cheaper than most any decent suspension anyway, and you can charge friends for future work to get some of the costs back.
Personally, for rough roads, I'd just get a nice comptech rear swaybar (I love mine). Set to the stiffest setting with otherwise stock suspension, it removed the majority of my body roll, and provides a little lift throttle oversteer. Most any aftermarket springs will be stiffer than stock, and you want stiffer if you lower it to avoid bottoming out.
SydneyLS
Nov 22, 2008 10:37 AM
Nicks95GSR
Jan 18, 2007 12:07 PM
Nicks95GSR
Nov 17, 2006 02:34 PM
stevey
Nov 4, 2003 02:52 PM
civic_luvr
10
Apr 9, 2002 08:52 PM
