crank pulley
Old Sep 13, 2005 | 12:49 AM
MenaceL.A.671's Avatar
Default crank pulley
i have a UR pulley on my lsvtec... and im just wondering if the mark is 0 btc or 16btc??? i only have one mark.. and **** i sold my stock pulley and i dont know no one with a stock.. so yeah i hope someone can reply.. thanks...
Old Sep 13, 2005 | 04:20 AM
95lstegman's Avatar
Default Re: crank pulley (m2slsvtec)
set your timing by it with a timing advance gun and set it for 0. if it runs really really sh!tty, set it to 16 on the advance gun.
Old Sep 13, 2005 | 07:18 AM
Default Re: crank pulley (95lstegman)
but see my pulley aint got the marks... it just has one? and my gun dont even have the dials.. soo my question is what is the UR pulley mark is it 0 or 16...
Old Sep 13, 2005 | 07:36 AM
95lstegman's Avatar
you know, your ignition timing shouldn't have changed just from putting this pulley on. go and check with your timing gun and see if it lines up, or at least if it's close. if it's within half-inch or so, your timing might still be off but at least then you know that that notch is +16deg BTDC. if it's way off, the notch is probably 0deg BTDC (in other words, it IS top dead center) and you're going to need a better timing gun.
NOTE: to anyone looking to purchase a timing gun, don't waste your time with a simple one. get an advance analyzer with inductive pick-up. it's more money but hey, you'll never need another one and it can do everything you'll ever need it to do.
Old Sep 13, 2005 | 02:41 PM
Sam92Teg's Avatar
If you still have the original crank pulley, hold it up in front of the installed one and see where the marks line up.
Old Sep 13, 2005 | 04:10 PM
95lstegman's Avatar
Default Re: crank pulley (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">If you still have the original crank pulley, hold it up in front of the installed one and see where the marks line up.</TD></TR></TABLE>
read foo. it says in the original post that he doesn't have the original.
boostedteg1203
Jun 15, 2010 03:16 PM
MenaceL.A.671
Sep 13, 2005 07:16 AM
Nick248
Sep 9, 2002 09:59 PM
