Suspension & Brakes Theory, alignment, spring rates....
getting some koni+gc's -- need some help
Old Sep 12, 2005 | 09:59 PM
alacard's Avatar
Default getting some koni+gc's -- need some help
as the title says, im ordering this package
http://www.ground-control-stor...I=681
im just wondering what spring rates i should go with.
i want a stiff ride, but it is a daily driver, and i wont be doing any autox or drag in the near future. Please any thoughts?
also, when i actually recieve the setup...will there be anything i need to do?, or is it just bolt-on?
--thanks in advance.
Old Sep 13, 2005 | 10:19 AM
TunerN00b's Avatar
Default Re: getting some koni+gc's -- need some help (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">as the title says, im ordering this package
--thanks in advance.</TD></TR></TABLE>
If your not going to put the car on the track, wouldn't the standard rates be best? I believe for an Integra, its 380/250, which would certainly be stiffer than stock.
Old Sep 13, 2005 | 10:46 AM
slammed_93_hatch's Avatar
ya just get the normal rates
Old Sep 13, 2005 | 02:41 PM
alacard's Avatar
but the thing is...it doesnt list the standard rates...so i wouldnt know what they are.
so for a civic would it be 380 fronts, and 250 rears?
Old Sep 13, 2005 | 03:36 PM
alacard's Avatar
well, i ordered them with 380/250 spring rates..but now for my second question:
anything i need to do before installation?
or is it just bolt on?
Old Sep 13, 2005 | 04:10 PM
bad-monkey's Avatar
Default Re: (alacard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">well, i ordered them with 380/250 spring rates..but now for my second question:
or is it just bolt on?</TD></TR></TABLE>
it's pretty much a bolt off bolt on affair. you'll be using the OEM top hats from the current shock assembly, so you'll need to disassemble those eventually, and you'll also need to cut the dustboots, if the DC came with the same metal ones that my bb6 did.
Old Sep 13, 2005 | 09:57 PM
alacard's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">it's pretty much a bolt off bolt on affair. you'll be using the OEM top hats from the current shock assembly, so you'll need to disassemble those eventually, and you'll also need to cut the dustboots, if the DC came with the same metal ones that my bb6 did.</TD></TR></TABLE>
hmm, yeah i was reading that in another thread...but it seems like these come all put together:
but im not positive...these seem like they come with everything ready to bolt on?
Old Sep 13, 2005 | 10:05 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">hmm, yeah i was reading that in another thread...but it seems like these come all put together:
but im not positive...these seem like they come with everything ready to bolt on?</TD></TR></TABLE>
oh duh, it comes with the GC top hats. yup, just bolt yours out and put these ones in after you put them together.
that's a great deal.
Old Sep 13, 2005 | 11:49 PM
KOALA YUMMIES's Avatar
You might have to smack the brake line bracket off the stock shocks but that takes 2 min.
Old Sep 14, 2005 | 10:49 PM
alacard's Avatar
Default Re: (KOALA YUMMIES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">oh duh, it comes with the GC top hats. yup, just bolt yours out and put these ones in after you put them together.
that's a great deal.</TD></TR></TABLE>
does that mean ill have to put the gc spring's on the koni shocks etc?...if so, does that mean ill have to preload them and what not?
--thanks for the info guys
Old Sep 14, 2005 | 11:02 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alacard &raquo;</TD></TR><TR><TD CLASS="quote">does that mean ill have to put the gc spring's on the koni shocks etc?...if so, does that mean ill have to preload them and what not?
--thanks for the info guys</TD></TR></TABLE>
yes. the shocks and GC's should come with instructions on how to put it all together. the good thing about the GC top hats (along w/ some other stuff) is that you will be able to preassemble the shock/springs before you wrench on the car itself.
don't worry about preloading the springs. just worry about what ride height you want, which will be a little painstaking.
Old Sep 16, 2005 | 10:00 PM
alacard's Avatar
arent there serious consequences to not preloading??
or are you just saying this because they come preloaded, and its not necessary?
Old Sep 16, 2005 | 11:55 PM
Preloaded with the rates I chose was higher ride height than stock, so its most likely not needed.
Old Sep 17, 2005 | 09:10 AM
sirg-vtec's Avatar
First of all, there is alot of miscommunication going on around here.
So listen up dude. I recieved my order and I installed the front yesterday and I am going to do the rears today.
-Everything is preassemble so all you have to do is take out the old and put in the new.
-There is no instructions.
-Just zip tie the brake brackets to the shock.
-The car sits lower than stock at the highest setting.
-I have 430 in the front and the rears are still stock but here's my 0.02$ The ride is almost like stock with a little bounciness on full soft. So far, I'm happy.
Old Sep 17, 2005 | 10:26 AM
Default Re: (sirg-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirg-vtec &raquo;</TD></TR><TR><TD CLASS="quote">First of all, there is alot of miscommunication going on around here.
The brackets come off with a screwdriver and a hammer in 2 minutes for both front stock shocks and they SLIDE on the Konis, theres no reason to not smack them off and dont say others are miscommunicating when you offer up shitty information like that
Taken from RJ. Koni shock install (read it next time douche)
Old Sep 25, 2005 | 10:20 AM
alacard's Avatar
so, no preloading at all, just: old ones out, new ones in?
thanks for all the help guys.
-I have 430 in the front and the rears are still stock but here's my 0.02$ The ride is almost like stock with a little bounciness on full soft. So far, I'm happy. </TD></TR></TABLE>
that kind of sucks...i really was wanting the stiff ride..i dont want it to feel stock at all.
Old Sep 25, 2005 | 12:02 PM
sirg-vtec's Avatar
Its stiff enough for the streets. You could always get new springs later if you feel like the ots rates is too soft for you.
Old Sep 26, 2005 | 09:38 AM
eg6cusco10pt's Avatar
i have the same set up can't beat it
ruffrhyder
Suspension & Brakes
Sep 1, 2008 08:51 PM
music462
Suspension & Brakes
Jul 28, 2008 01:20 PM
ITRswapandslow
Feb 10, 2004 02:18 PM
Burke
Dec 16, 2003 09:18 AM
Sportmode
Apr 25, 2003 11:10 PM
