???Difference in D16Y8 and D16Y7???
Old Sep 12, 2005 | 06:25 PM
travcivex's Avatar
Default ???Difference in D16Y8 and D16Y7???
So I just blew my bearing on my number 1 rod and it sent the rod and piston for a joy ride, they destroyed my block... to make a long story short... i need a new block! i own a 00 civic ex with the stock d16y8, i have my HANDS on a d16y7 full motor and trans... i want to take my head off the y8 and stick it on the y7, is this possible??? i would think it would be but the valve angles might be diff and i don't know bout anything else... please help!!! any info is good info, THANKS!!
Old Sep 12, 2005 | 06:27 PM
SOHCejcivic's Avatar
Default Re: ???Difference in D16Y8 and D16Y7??? (travcivex)
the blocks are exactly the same. stick they y7 block in and you'll basically still have a y8.
Old Sep 12, 2005 | 06:37 PM
travcivex's Avatar
any compression change? i just want to use a oe head gasket, also do you think the trans are any weaker?
Old Sep 12, 2005 | 06:41 PM
Default Re: (travcivex)
nope. you'll have a y8 (basically)...but it'll say y7 on the block. they're the same so there will be no changes in compression/power. stick with your y8 tranny. the y7 has longer gears.
Old Sep 12, 2005 | 06:46 PM
travcivex's Avatar
Default Re: (SOHCejcivic)
really? dang, cuz my y8 trans 2nd is messed up, (hard to shift into, once in pops out easy.. yata yata yata.... maybe i'll try the y7 trans for a while and slightly build the y8... i dunno... do you know where i could find specs for trans ratios? or what might be wrong with my trans? i'm figuring sincros and or bent shift fork, i'm kinda alone on the whole ej8 since all my friends run k's and the few who do run d's are just... well muffler shop specials... thanks for your input by the way
Old Sep 12, 2005 | 06:49 PM
http://www.sohchonda.com > transmissions. i had a broken 1-2 shift fork on mine. kicked out of second sometimes, or just fell out while cruising (low rpm, parking lots)
you'll definetly want to rebuild it. so go with the y7 so you can drive and not be rushed to fix the y8
Old Sep 12, 2005 | 06:51 PM
travcivex's Avatar
sounds exactly like mine! it's so damn annoying and embarrasing,
Old Sep 12, 2005 | 06:59 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">http://www.sohchonda.com &gt; transmissions. i had a broken 1-2 shift fork on mine. kicked out of second sometimes, or just fell out while cruising (low rpm, parking lots)
you'll definetly want to rebuild it. so go with the y7 so you can drive and not be rushed to fix the y8</TD></TR></TABLE>
yeah, i'm rockin the d16y7 tranny on my d15b7 and it's not nearly as horrible as the 92-95 cx/vx tranny.
cevinklark
Dec 31, 2005 07:32 AM
JonGP4
29
Nov 21, 2003 10:35 PM
EJ6-
Aug 20, 2003 11:01 AM
