h22a with h23a mods
Old Sep 12, 2005 | 05:55 PM
lude1888's Avatar
Default h22a with h23a mods
I am going to install an h22a engine instead of the h23a1 in my prelude si. I am wondering though if any of my modifications will still bolt-on on the new engine. They are: AEM powerpullies, Aem intake DC-S headers, 10.3 mm wires and spark plugs. Please any info on reuseable parts would be helpful. Also can I run the tranny from the h23a1 on the h22a engine.
Old Sep 12, 2005 | 06:00 PM
AndyD's Avatar
Default Re: h22a with h23a mods (lude1888)
Intake and pullies are the only things that will swap onto the H22.
Yes, you can run the H23 tranny but it is not the better choice between and H22 and H23 tranny.
Old Sep 12, 2005 | 06:20 PM
high_revs's Avatar
i would reccomend usdm h22 trans not jdm h22....my h23 trans has shorter gears than the jdm h22 trans. maybe its just in the final, i dont really know but this is in comparisson to my friends full h22 jdm swap and my h23 tranny on my h22 swap.
Old Sep 12, 2005 | 06:46 PM
AndyD's Avatar
Default Re: (all mOtor h23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all mOtor h23 &raquo;</TD></TR><TR><TD CLASS="quote">i would reccomend usdm h22 trans not jdm h22....my h23 trans has shorter gears than the jdm h22 trans. maybe its just in the final, i dont really know but this is in comparisson to my friends full h22 jdm swap and my h23 tranny on my h22 swap.</TD></TR></TABLE>
What? Your H23 tranny has SHORTER gears compared to an H22 tranny?? How is that possible? Also, the 4th Gen USDM AND JDM trannies have the SAME gears. The USDM 5th gen H22 tranny has slightly longer gears compared to the 4th Gen tranny, but slightly shorter gears than the H23 tranny.
Old Sep 12, 2005 | 07:35 PM
high_revs's Avatar
well in comparrison i run out of gears a lot faster to the same amount of rev's..and at 80 im about 4,000 rpms and he's only like 3,500. im sure mines is h23 trans, but i'll check his tranny code to identify it better.
Old Sep 12, 2005 | 07:58 PM
mgags7's Avatar
^^thats a load of crap, my m2b4 puts me at 4k at 80, yours should be at 3500....
maybe you and your friend accidentally switched trannys during the swap....
Old Sep 13, 2005 | 04:11 AM
v4lu3s's Avatar
RTFM
asfaik teh h23, and all 4th gen h22 trannies have the same final drive.
and the h23 and jdm 4th gen tranny have nar identical 4th gear. 2nd 3rd and 5th are a little bit different though.
Old Sep 13, 2005 | 05:52 AM
high_revs's Avatar
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">^^thats a load of crap, my m2b4 puts me at 4k at 80, yours should be at 3500....
maybe you and your friend accidentally switched trannys during the swap....</TD></TR></TABLE>
lol nahhh we did his swap first and mine about a year later. i kept my h23 trans he got the whole jdm h22 swap with trans and everything. i got usdm swap.....i'll check the tranny codes tonite tho.
Old Sep 13, 2005 | 09:38 AM
Dougs96SI's Avatar
At 80 MPH, my H23 tranny has me around 4k.
Old Sep 13, 2005 | 02:54 PM
high_revs's Avatar
Default Re: h22a with h23a mods (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">
At 80 MPH, my H23 tranny has me around 4k.</TD></TR></TABLE>
thank you
Old Sep 13, 2005 | 02:58 PM
Lewdin' Incognito's Avatar
Default Re: h22a with h23a mods (all mOtor h23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">At 80 MPH, my H23 tranny has me around 4k.</TD></TR></TABLE>
I have h23, 80mph @ 3400-3500. But then again, mine is auto - is there that much of a difference in the final gearing?
Old Sep 13, 2005 | 03:01 PM
Dougs96SI's Avatar
Default Re: h22a with h23a mods (Lewdin' Incognito)
Autos are way different.
Old Sep 13, 2005 | 03:36 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">Autos are way different.</TD></TR></TABLE>
word
Old Sep 13, 2005 | 03:44 PM
AndyD's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">asfaik teh h23, and all 4th gen h22 trannies have the same final drive.
and the h23 and jdm 4th gen tranny have nar identical 4th gear. 2nd 3rd and 5th are a little bit different though.</TD></TR></TABLE>
JDM and USDM 4th Gen H22 trannies have the same gearing.
H22 and H23 trannies share the same 1st and 5th Gears. 2nd, 3rd, and 4th are different.
Old Sep 13, 2005 | 05:19 PM
cd6SiR
Guest
Posts: n/a
Default Re: (AndyD)
my m2b4 puts me at 4,000rpm's when im at 85mph
Old Sep 13, 2005 | 07:22 PM
krnfly2damoon's Avatar
Default Re: (cd6SiR)
my near stock h23a1 has 80mph @ 4k rpm
Old Sep 25, 2005 | 08:50 PM
twilightprotege's Avatar
Hi I'm a Honda noob, but I just want to clarrify something.
A H23A gearbox will bolt on to a H22A and therefore F20B right?
I ask because I can get a H23A gearbox and F20B engine quite cheap (the F20B comes with auto which i'd ditch) and if the above is correct saying the H23A has shorter gears that'd be better for drag racing and circuit work (what my car will be set for).
one thing as well, and i cant find anything on this so it might be an Australian only gearbox or something, but the H23A gear box available has a code M2K4. that code is not showing up anywhere here and it pretty much not on the internet. would anyone know if it has an LSD or not?
is there any strength difference betwen h23 boxes and h22 boxes? from what i have heard honda gearboxes are basically indestructible...
Old Sep 25, 2005 | 09:02 PM
4LugR's Avatar
Default Re: (twilightprotege)
i dont kno about honda gearboxes being indestructable... i know a lot of people who have a lot of tranny problems....
Old Sep 25, 2005 | 09:16 PM
well not indestructible, but pretty good in comparison with other fwd boxes made by other manufacturers (mazda for example in my protege5 is weak as p!ss)
MJT805
Apr 30, 2009 11:06 AM
erk89
Dec 23, 2008 04:23 PM
EJ6SON
Jun 18, 2008 08:17 PM
live2ride31
Jan 29, 2007 12:03 PM
rjrmotorsport
Sep 24, 2003 09:46 AM
