steel intake manifold, sheet..... anybody made one?
Old Sep 12, 2005 | 12:32 PM
redzcstandardhatch's Avatar
something different
Default steel intake manifold, sheet..... anybody made one?
like the topic says, has anybody ever made a steel sheetmetal intake for a honda? i searched , but got nothing.....just curious. i'm in process of fabbing mine.
-cheap
-easy to work with
-cheap
-already had steel velocity stacks that will work perfect as runners
-cheap
Old Sep 12, 2005 | 01:58 PM
E-Rok's Avatar
EPIC TUNING
Default Re: steel intake manifold, sheet..... anybody made one? (redzcstandardhatch)
steel holds heat more than aluminum which is bad for intake air temps.
Old Sep 12, 2005 | 02:03 PM
ManBearPig4silly's Avatar
^^what he said^^
You could just copy the design of an AL manifold only in steel...
And doesn't your brother have a tig?
Old Sep 12, 2005 | 04:56 PM
fork's Avatar
you can't make something cool like that and not post pics
If you worried about heat you can get it ceramic coated, that will help
Old Sep 12, 2005 | 05:18 PM
E-Rok's Avatar
EPIC TUNING
Default Re: (fork)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fork &raquo;</TD></TR><TR><TD CLASS="quote">you can't make something cool like that and not post pics
If you worried about heat you can get it ceramic coated, that will help</TD></TR></TABLE>
ot really, the engine is going to radiate heat on it and its going to act as a heak sink. ceramic coating will help is absorb heat from around it, but not from within.
Old Sep 12, 2005 | 05:57 PM
something different
theoretically, aluminum absorbs heat faster than steel...(if it is the same thickness, etc.)
using a phonelic gasket, it should be decent.......
i'm debating ceramic coating it....not sure. we'll see.
oh, and yeah, my brother and i have a tig david.......and we could do aluminum....but it really is more of a pain, and costly. total budget for this manifold-85 bucks.
guess nobody has really done this....oh well. cool.
Old Sep 13, 2005 | 08:00 AM
Make sure you bring it up sometime so I can see it.
Old Sep 13, 2005 | 09:56 AM
xci_ed6's Avatar
aluminum changes temperature faster, heat is a constant.
but overall i think the differences will be nil. The aluminum will heat up faster, and it will transfer heat to the air (internal and external) faster.
Plus after any sgnificant run time with the hood closed the manifolds will both be the same temperatures.
Old Sep 13, 2005 | 10:24 AM
http://www.sdsefi.com/techinta.htm
Old Sep 13, 2005 | 08:49 PM
something different
Default Re: (I4sillypwr)
awesome find david.
very good info too. mine will be fashioned after the supra intake manifolds that MVP motorsports makes. i'll see if i can find a picture of one...
will have a HUGE plenum, with velocity stacks as the runners. REALLY short runners.
Old Sep 14, 2005 | 10:30 AM
So when are you gonna build a sweet exh manifold for that sucker? I have like 12 mild steel weld els you can have for like free. I like stainless
edit: here is where that link came from. Crap loads of sweet tech articles.
http://www.sdsefi.com/tech.html
Old Sep 16, 2005 | 06:42 PM
something different
i'll take em david! PM me your phone # if you read this........or i'll PM you on ef-honda
Old Sep 16, 2005 | 07:19 PM
RCautoworks's Avatar
Default Re: (redzcstandardhatch)
He makes them
https://honda-tech.com/zero...04364
And for 20 bucks a piece.
Old Sep 19, 2005 | 02:53 PM
something different
yeah, but he doesnt make them for a sohc right now, doesnt want to make a single one........understandable.
i'm sending a gasket to exploited soon, whenever i get around to it. he said he'd do it for 65 bucks.
Old Sep 27, 2005 | 11:57 AM
JK_Motorsports's Avatar
Is there not a fear of Corrosion using steel. I was think of using steel, but now am leaning toward aluminum because of the corrosion factor.
Old Sep 27, 2005 | 12:10 PM
Flashmn's Avatar
Default Re: (bumblezc)
It takes a while to rust through, so I wouldnt worry about it. I have a steel manifold for my weber dcoe's.
Old Sep 27, 2005 | 02:21 PM
beepy's Avatar
There are only two reasons aluminum is used to make intake manifolds. One, it is about as lightweight as you can go cheaply. Two, and more importantly, aluminum is easier to cast and machine. If manufacturers had to weld manifolds together, bets are good that most would choose steel as a material.
On the other hand, most of the 60's and 70's cars I have owned had iron intake manifolds, until I swapped them out for aluminum.
RACEPAK
Welding / Fabrication
Feb 9, 2010 07:36 AM
redzcstandardhatch
Sep 9, 2005 03:34 PM
smooth95
Aug 11, 2005 11:16 AM
743power
Jan 13, 2005 08:13 AM
zberger
Nov 20, 2003 01:46 AM
