act 8.8 flywheel(wont start)
just installed a motor with a complete act flywheel and clutch and now it wont start up...it will crank but it seems as if something is holding it back to make it start...everything words fine but such as fuel and spark but it wont start up...please help thankx
So what exactly happens? It cranks, but just doesn't start? Did you check grounds? I'd check grounds first since you just installed the motor.
So your getting spark and fuel, guess that only leaves your distributor being installed 180* out of time. I believe that is only possible on 91 or older distributors.
If that isn't it, then you have a weak spark condition, plugs in wrong order, weak battery or starter, bad connections to starter, battery or grounds, or you aren't getting fuel via the Main Fuel Relay.
NeverLift
May 9, 2009 03:06 PM
Exempt
Aug 26, 2005 01:00 PM
