Rounded off bolt in Throttlebody.......time for a new one!
Well, after trying to fix my Fast Idle Valve thing on the Throttlebody on my B16.....I rounded a bolt..
This damn thing is hard to get to (have to comeup from bottom to get to bolts!
Anyways, I'm too feedup right now.....I think I just wanna get a new throttlebody and start from scratch.
What is a good Throttlebody to get with Fast Idle Valve already installed.? BBK ? or what ? Good priced too please
Most aftermarket throttle bodies either eliminate the FITV or they dont come with one. You will have to use your current valve. However, if its just a bolt, I would just replace that and stick with stock TB and FITV.
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX »</TD></TR><TR><TD CLASS="quote">Most aftermarket throttle bodies either eliminate the FITV or they dont come with one. You will have to use your current valve. However, if its just a bolt, I would just replace that and stick with stock TB and FITV.</TD></TR></TABLE>
I eliminated my FITV and have had really no problems. The only thing is when it's really cold it takes a fw more cranks to start up. I haven't seen any aftermarkte TB that retains the FITV. BTW it's easier to remove the bolts on the FITV when the TB is removed from the intake mani.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed »</TD></TR><TR><TD CLASS="quote">So.....How do I eliminate the valve ? Cause mine is not working !</TD></TR></TABLE>Get a throttle body that doesn't have one. DA tegs work well for this, thats what I used.. Plus aftermarket TBs are a waste of money unless your putting it on a strictly track car..
eagleclawracing
Sep 15, 2006 01:57 PM
hondaracin24
May 10, 2005 04:38 PM
