Chipped P28 w/B18C swap?
Old Feb 27, 2002 | 01:15 PM
Stop the Beast's Avatar
Default Chipped P28 w/B18C swap?
I'm planning on using a chipped P28 with my B18C. Is this a common and a good setup? The chip will be the FF Special 1 from JDMHondaparts.com. They says it a base Mugen program tweaked a bit. Anyone have any Input or opinions, etc, etc.
Old Feb 27, 2002 | 01:18 PM
KraZyCHOWMEIN's Avatar
Default Re: Chipped P28 w/B18C swap? (brokstar)
ur getting the mugen program dont believe the hype, and yes this is a common setup, meaning using a chipped P28 (civic ex ecu) in a b series. Have fun
Old Feb 27, 2002 | 02:54 PM
Default Re: Chipped P28 w/B18C swap? (KraZyCHOWMEIN)
I also doubt it'll be a Mugen program, but hopefully a decent clone.
Old Feb 27, 2002 | 03:32 PM
naw i mean its a copy of the mugen program dont get me wrong, but most likely how they hype it up and say the tweaked it isnt true thats all im saying
Old Feb 27, 2002 | 04:32 PM
Mr. Softee's Avatar
i wouldnt run a p28 with your gsr motor. the p28 wont open the secondary butterflies... and the p28 doesnt have a knock sensor
Old Feb 27, 2002 | 07:22 PM
Default Re: Chipped P28 w/B18C swap? (94goldjungsr)
Most of the aftermarket ECU programs I've seen eliminate the K.S. and I'll be using a Skunk2 IM. Do you know why they eliminate the K.S.? Thanks.
Old Feb 27, 2002 | 07:25 PM
Mr. Softee's Avatar
becuase they dont come with one. only the gsr ecu has one.
Old Feb 27, 2002 | 07:38 PM
1 2 NV's Avatar
use the P28 ECU. the ECU does not open the secondary butterflies on a GSR manifold. its vacuum. so whether u have a GSR ECU or another ECU, the secondaries will open.
Old Feb 27, 2002 | 07:49 PM
Default Re: Chipped P28 w/B18C swap? (hondaatwsu)
I won't have a secondary butterfly. Thanks for the input all
[Modified by brokstar, 4:50 AM 2/28/2002]
Old Feb 27, 2002 | 08:51 PM
t's Avatar
t
Are you sure about that?? The vacuum wont open the butterflies; It is an electrically controlled solenoid.
You can use a RPM activated switch or VTEC controller to control the butterflies if you use the P28 ecu.
[Modified by t, 9:58 PM 2/27/2002]
Old Feb 27, 2002 | 09:06 PM
1 2 NV's Avatar
Default Re: Chipped P28 w/B18C swap? (t)
ok, let put it this way. i installed a 00 B16 block w/ 98 GSR head on it. hooked everything up (had to T the vacuum line goin into the back of the manifold), didnt have the right ECU at the time. used the stock VX ECU and viola, secondaries kick in, go figure.
Old Feb 27, 2002 | 09:14 PM
Mr. Softee's Avatar
i dont buy that.
Old Feb 27, 2002 | 09:21 PM
t's Avatar
t
Are you sure that it was not always open
Old Feb 27, 2002 | 09:31 PM
hybrider's Avatar
Old Feb 27, 2002 | 11:06 PM
nfn15037's Avatar
Default Re: Chipped P28 w/B18C swap? (hybrider93)
Yeah, they were always open. They are controlled by the ECU. Maybe you were mistaking VTEC for the secondairies opening? VTEC is at 4400 and the secondairies open @ 5700.
Old Feb 28, 2002 | 06:59 AM
eg6ajk's Avatar
there were only two ecus for which secondary butterfly control came standard, P72 and P13 (prelude)....
there is no way the VX could control the butterflies unless, further modification takes place
sloppy_seconds's Avatar
Banned
Default Re: Chipped P28 w/B18C swap? (nfn15037)
back to the original topic, get the chipped P28. the only thing is that you have to decide what program you want. www.locashracing.com also does the ecu programming and he has tons of programs. i also think that kenji on this board does them (not sure though). the new ecu will wake your car up like no other, just decide on what program is right for you.
--justin
[Modified by slowasscx, 5:52 PM 2/28/2002]
Old Mar 2, 2002 | 02:37 PM
Default Re: Chipped P28 w/B18C swap? (slowasscx)
Just to let you all know. I decided to go with the Skunk2 mapping from locash racing with a 8800 rev. limiter and vtec at 5200.
Old Mar 5, 2002 | 08:22 AM
Banned
let us know how you like it
--justin
Old Mar 5, 2002 | 08:57 AM
GokuSSJ4's Avatar
Default Re: Chipped P28 w/B18C swap? (eg6ajk)
chipped p28 with a b18c swap . should be good , but im not to crazy of running a mugen program spec, i use to have similar to mugen program and it runs way to rich in some parts and less gas miles .now im running ericks racing custom program and is good performance and also better gas milage
undagroundrican
Jan 22, 2005 10:23 PM
blackANESE
Dec 4, 2003 06:17 AM
slowassgsxr750
May 4, 2003 03:21 PM
CBR
14
Aug 23, 2002 10:56 AM
Stop the Beast
Feb 27, 2002 02:52 PM
