transmission bearings
Old Sep 12, 2005 | 07:27 AM
scherzo's Avatar
Default transmission bearings
source of transmission bearings other than the dealer, '94 civic VX. Also are failed bearings common in these transmissions?
Old Sep 12, 2005 | 07:49 AM
Kyles ej1's Avatar
Default Re: transmission bearings (scherzo)
you could always get a used transmission and it would be alot easier to fix than the bearing.....and yes failed bearings are in almost all honda transmissions
Old Sep 12, 2005 | 08:37 AM
scherzo's Avatar
Default Re: transmission bearings (93ejay1)
yes, it would be easier to just replace with a used trans, but I want the VX gear ratios for economy and havent found one with low miles. Do you know of other models have the same or similar ratios that would work in my car '94 civic VX?
Old Sep 12, 2005 | 08:39 AM
JDM-97CX's Avatar
What bearing do you need? Most aftermarket parts suppliers will carry them. What makes you think you have a bearing that has failed?
komat's Avatar
check the honda-tech market.
im sure someone has one for sell there.
should of join ht a month ago.
i gave away my cx tranny for free. it had 116k miles on it but was in perfect shape.
Old Sep 12, 2005 | 09:46 PM
Mista Bone's Avatar
D Tranny Guru
GearSpeed or online dealer.........
describe the failed bearings
B17SolRide
Mar 20, 2018 07:05 AM
vinuneuro
Transmission & Drivetrain
Oct 4, 2010 04:45 PM
cfilipski
Oct 3, 2006 07:15 PM
LsTurbo91
Jul 16, 2002 08:00 PM
John
Jul 5, 2002 08:52 AM
