Distributer rotor screw help
Old Sep 11, 2005 | 11:03 PM
blkgsr03's Avatar
Default Distributer rotor screw help
I attempted to change out my dist. cap and rotor but i ran into a lil prob, i couldnt get the screw out from the rotor! i stripped it just a lil bit n got scared and seeing if anyone had this prob. should i spray wd-40 to lube it? i willl try again tomorow. What if the screw is stripped, is there any way to get the rotor off or the screw?
yeah i tried again... its strripppped...
new vs old.. does it look bad.?
Modified by CTRb18c at 12:08 PM 9/14/2005
Old Sep 11, 2005 | 11:12 PM
civic_driver's Avatar
don't spray it with anything... it would make it even harder to take out since it will be slippery
another member was going to try jb welding a screw driver to the screw... if you go this route, tape anything but the screw.. you don't want to weld anything but the screw and screwdriver
You could try drilling into the screw's head with a dremel or some tiny wheel of kind to make a new channel for the screwdriver
or you could use "easy out" to extract the bolt... just be careful
Old Sep 11, 2005 | 11:48 PM
hatchi's Avatar
Default Re: Distributer rotor screw help (CTRb18c)
use a drill to get it out. always worked for me
Old Sep 12, 2005 | 12:32 AM
dmxsoulja3's Avatar
Default Re: Distributer rotor screw help (hatchi)
worse case pull the dizzy, mark it, or make setting your timing part of your tune up
Old Sep 12, 2005 | 12:45 AM
RedlinedVTEC's Avatar
Default Re: Distributer rotor screw help (dmxsoulja3)
Grind the head off and when you get the cap off the bolt wil have no tension on it and screw out by hand.
Old Sep 12, 2005 | 02:46 AM
johniericeboy's Avatar
Default Re: Distributer rotor screw help (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Grind the head off and when you get the cap off the bolt wil have no tension on it and screw out by hand.</TD></TR></TABLE>
just be carefull and take your time, if the screw is still tight you can use a pair of mole grips(vicegrip) to get it turning
Old Sep 14, 2005 | 09:09 AM
blkgsr03's Avatar
does the rotor look bad?
Old Sep 14, 2005 | 09:13 AM
komat's Avatar
i had this happen to my yesterday
what i did was break the plastic off the rotor
then used a vice grip to loosen the screw
but you need to get a new screw off a dealer b4 you do this
FLiPFeLLaH's Avatar
u should get a new car
blkgsr03's Avatar
Default Re: Distributer rotor screw help (komat)
oh yeah i have a new screww new everything ready to go in.
Old Sep 14, 2005 | 09:17 AM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CTRb18c &raquo;</TD></TR><TR><TD CLASS="quote">does the rotor look bad?</TD></TR></TABLE>Its lookin a little rough.
Old Sep 14, 2005 | 10:22 AM
Redline96LX's Avatar
* B A N N E D *
Default Re: Distributer rotor screw help (HondaFanatic708)
Yeah the rotor could use with replacing, kind of a lot of carbon on the contact tab.
I did this about 2 months ago, and lucky me, i had a LARGE screwdriver (i mean over a foot long) and twisted hard once, that worked. Don't twist harder and harder, give it one hard twist. That screw is wide and meant for a very big screwdriver.
IF that fails, might try takin a dremel. Hack at the old dizzy cap, so that you can get the tips of a big set of vice grips on the screw. Also could take a dremel to the screw if its stripped, make a line, and go at it with a flathead.
Old Sep 14, 2005 | 10:37 AM
dat_flip's Avatar
i used an impact screwdriver........ it worked good
Old Sep 14, 2005 | 11:15 AM
civic_eg-o's Avatar
I've had this happen to me and what I did I broke the top off the rotor and with sone pliers broke the plastic around the scew and used some pressure pliers to get the screw out. wd40 will help. when you get the screw out the metal ring(inside part of the rotor) might be stuck to the distributor shaft here you will need a pair of pliers and a long standard screw driver. losely put the pliers around the distributor shaft as to catch on the ring. then pry on the pliers with the screwdriver while you hold the pliers, but do not squeeze the pliers. make sure you find a strong area to pry from
Sir Kyle
May 10, 2008 06:30 PM
LukieLuc
Apr 2, 2007 06:13 PM
thaseint
Suspension & Brakes
Feb 6, 2007 06:38 PM
lostkoz
Mar 12, 2006 11:02 AM
gsrvx
Jun 7, 2002 12:54 PM
