99-00 OEM Civic Foglight question
Old Sep 11, 2005 | 10:59 PM
HYPEBEAST!'s Avatar
Default 99-00 OEM Civic Foglight question
I just installed foglights for my car...and i was wondering if i can make my fog lights independent. Basically, i can turn them on and off whenever i want it; as of right now it turns on when the headlights turn on. Is there any other way besides tapping with parking lights?
Old Sep 11, 2005 | 11:04 PM
BoostedJeff's Avatar
Default Re: 99-00 OEM Civic Foglight question (JAYDMEM1)
run them entirely on their own power source, dont tap into anything, except a 12v source and a ground. then just run the switch. you can have it on whenever the hell you want then
Old Sep 11, 2005 | 11:12 PM
HYPEBEAST!'s Avatar
so dont use the relay at all?
Old Sep 12, 2005 | 07:13 AM
HYPEBEAST!'s Avatar
Default Re: 99-00 OEM Civic Foglight question (BoostedJeff)
Old Sep 12, 2005 | 07:14 AM
ek_99_SiR's Avatar
wire them to a switch...?
Old Sep 12, 2005 | 08:53 AM
intenseEK's Avatar
Default Re: 99-00 OEM Civic Foglight question (ek_99_SiR)
you could wire them to the power wire that lights up the parking lights or you can tap the power wire from the fogs into the stereo. i forgot how i did it but i got them to turn on and off whenever i want.
Old Sep 12, 2005 | 09:26 AM
Steve-'s Avatar
http://www.angelfire.com/sc3/nguyen/How_to.htm here you go
Old Sep 12, 2005 | 09:53 AM
hasback*'s Avatar
F*CK THIEVES!
Default Re: 99-00 OEM Civic Foglight question (dc4 integi2a 00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc4 integi2a 00 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.angelfire.com/sc3/nguyen/How_to.htm here you go
i was just about to post that . thats how i did mine .easy took about 10 minutes
Old Sep 12, 2005 | 10:02 AM
HYPEBEAST!'s Avatar
PERFECT!!! tiiight!
Old Sep 12, 2005 | 05:06 PM
Steve-'s Avatar
i hope it helps
Old Sep 12, 2005 | 06:51 PM
HYPEBEAST!'s Avatar
i just wired everything up now according to your guide...now my cluster/climate control bulbs wont light up at all..any ideas?
Old Sep 12, 2005 | 06:53 PM
Undercover_Skank's Avatar
wtff......
Old Sep 12, 2005 | 07:11 PM
HYPEBEAST!'s Avatar
Default Re: 99-00 OEM Civic Foglight question (sleepyzze110)
hahaha just did that...instrument fuse blew!
Old Sep 12, 2005 | 07:23 PM
mulletov's Avatar
cool writeup, any pics of the new setup? will a tiny screwdriver work good enuff?
Old Sep 12, 2005 | 09:17 PM
HYPEBEAST!'s Avatar
Default Re: (mulletov)
honestly i'd use one of those metal toothpick things that dentists use...its much easier than a jewler's tool, cause one plug took me like 10 mins to get out...maybe i just suck ..but thats my opinon
Old Sep 12, 2005 | 09:20 PM
HYPEBEAST!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyzze110 &raquo;</TD></TR><TR><TD CLASS="quote">check fuse?</TD></TR></TABLE>
btw who ever does this...change your instrumental fuse from a 7amp to a 15 amp
Old Sep 14, 2005 | 10:37 AM
exsinnovation's Avatar
people do that all the time when they cant find the right fuse and the need one to replace the blown one.
Old Sep 14, 2005 | 11:50 AM
JDMSiGuy17's Avatar
Default Re: (exsinnovation)
nam send me some pics!!! if you got the kit it should have come with its own relay that goes in the dash for you to use!
Old Sep 14, 2005 | 02:06 PM
Ryan.'s Avatar
Default Re: (JDMSiGuy17)
My kit cam with the relay and then I attached it to the battery for its own power sorce and grounded it. Simple, works whenever I hit the button
Old Sep 14, 2005 | 05:04 PM
JDMSiGuy17's Avatar
Default Re: (R_star)
is it the same kit i got nam? if so it should have come with its own relay but just hook it up to your own switch and it should be good!!!
christiantequila
Mar 5, 2008 06:32 AM
kiddcarbuff
May 10, 2007 01:48 PM
HYPEBEAST!
Sep 12, 2005 07:10 AM
GreenEX
Jan 8, 2004 06:36 PM
JDM CTR EK
Jun 13, 2003 09:51 PM
