ebay strut bars
Old Sep 11, 2005 | 09:54 PM
89a6T's Avatar
Default ebay strut bars
are these worth buying? right now i have no suspension upgrades. im putting together 2-275whp daily driver. i dought it will ever be autoXd.im getting aftermarket springs & struts.
Old Sep 13, 2005 | 07:11 AM
JamesV's Avatar
they will either snap or not fit.. if that doesnt happend then yea i guess its worth it. every strut bar is the same in my opinion. i guess your just paying for the brand..
Old Sep 13, 2005 | 08:21 AM
Suck my DX's Avatar
Default Re: (james4o8)
they are all the same...ive had name brand and generic....if someone out there can tell a difference in driveability between generic and name brand id like to hear what they have to say
Old Sep 13, 2005 | 08:24 AM
driveahonda's Avatar
they work just how they are supposed to.. once you have them tightened all the way, weld the mounting brackets to the actuall strut bar and there you go
Old Sep 13, 2005 | 09:20 AM
Tyson's Avatar
Default Re: ebay strut bars (89a6T)
i only have used and would only consider the neuspeed front strut bar. and i personally like it and know its making a difference in stiffening the front of the chassis.
however, do not consider it a suspension device. its nothing like adding a swaybar or changing springs. strut bars dont even belong in the same sentence as swaybars.
i dont care for ebay bars. i wouldnt bother with them, just because im a snob.
Old Sep 13, 2005 | 10:04 AM
dohdoh420's Avatar
Default .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">they are all the same...ive had name brand and generic....if someone out there can tell a difference in driveability between generic and name brand id like to hear what they have to say</TD></TR></TABLE>
I totally agree with you on this. "if it fits, where it", correct me if I'm wrong; but somthing I have came up with for the difference in performance is this; Ebay strut bars (well the ones I've seen) are tubular, and more than likley hollow, meaning when stress it put on them they will tend to twist more or have more give since they are hollow, compaired to a DC sport one or any other brand where theirs are solid and/or more of a rectangle, and being solid there is no gap of air for them to give into, forcing the body to stay in one place more. and other than that, if thats true or not, I belive you pretty much pay for the brand name and appearance.
Old Sep 13, 2005 | 10:23 AM
89a6T's Avatar
so the bars are just decorations then?
Old Sep 13, 2005 | 10:25 AM
Suck my DX's Avatar
Default Re: (89a6T)
they do a little but dont expect too much...i think u will be happier with a quality sway bar set up
dohdoh420's Avatar
Default Re: (89a6T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89a6T &raquo;</TD></TR><TR><TD CLASS="quote">so the bars are just decorations then? </TD></TR></TABLE>
I'm not saying that, I'm saying the ebay ones probably twist just a little more, problaby not enough to make a big difference, and I'm saying when buying a brand name one you are paying for it to look better than the ebay ones that are just plain silver.
Old Sep 13, 2005 | 11:09 AM
WhiteSiDan's Avatar
Default Re: (dohdoh420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohdoh420 &raquo;</TD></TR><TR><TD CLASS="quote">
I'm not saying that, I'm saying the ebay ones probably twist just a little more, problaby not enough to make a big difference, and I'm saying when buying a brand name one you are paying for it to look better than the ebay ones that are just plain silver.</TD></TR></TABLE>
All of my spoon bars are plain silver...I think they look good plain...he should just go cheap if he doesn't care about name brands!!!
Old Sep 13, 2005 | 11:20 AM
Tyson's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">they do a little but dont expect too much...i think u will be happier with a quality sway bar set up</TD></TR></TABLE>
gahhh!! why do you even bother comparing the two!
thats like comparing a goddam new shift lever to an intake.
Old Sep 13, 2005 | 11:37 AM
ohjolt2's Avatar
I think its time for you to give up and let them have the thread.
Old Sep 13, 2005 | 11:41 AM
Tyson's Avatar
Default Re: (ohjolt2)
:unsubscribed:
Old Sep 13, 2005 | 11:55 AM
RCautoworks's Avatar
Default Re: (WhiteSiDan)
I did a little test and asked people that owned strut bars if they noticed a difference, it was a 50/50 kind of deal. Look into fender braces if you are really looking to stiffen the chassis up.
Old Sep 13, 2005 | 02:30 PM
Ti Rider's Avatar
Well....ebay strut bars have threaded adjustments. Strut bars are supposed to keep the front end twisting. How will a threaded adjustment prevent that? Here's the answer - they won't. They might provide a tiny bit of fender to fender stiffness but little else. A solid bar with no threaded adjustments is the way to go (Neuspeed). I recently put one on my mostly stock 89 CRX Si and could feel a improvement (don't expect miracles, it just makes the front end more solid...).
Old Sep 13, 2005 | 05:20 PM
Crx Jimmy's Avatar
Default Re: ebay strut bars (Ti Rider)
i have a neuspeed and have had cheap ebay ones, either way they do make a difference, on my crx if i jacked up the rear on the side by the jacking point if you opened the hatch when jacked up- the hatch would actuall hit the body and scrape the paint when the strut bar is on the body doesnt twist- so it does something noticible, also the dc ones are worse than ebay ones has anyone actuall pushed on them they flex over 2" when pushed on my $10 ebay bar wouldnt bent more than a mm or 2
PhatFactory
51
May 8, 2009 11:10 PM
lilvietboy
Sep 4, 2008 09:13 AM
EJ8 GSR-T
Suspension & Brakes
Jul 20, 2005 10:51 PM
electron-eg
17
Jan 5, 2004 02:19 PM
daniel89civ
Feb 9, 2002 02:36 PM
