will this header fit my integra??
Old Sep 11, 2005 | 09:27 PM
watsvtecEK's Avatar
Default will this header fit my integra??
i came accross a dc 421 one piece header and it said it was for a b16, 99 civic si... well it also said it can fit some other b- series engines but may require fabrication... well i was wondering if they will fit my 93 integra ls b18, with no or just slight modifications, and what needs to be done to them? here is the pn HHC5504 .
thanks
Old Sep 11, 2005 | 09:33 PM
LSRracing95's Avatar
Default Re: will this header fit my integra?? (b18tegra)
it will bolt up to the head and fit... the flange on the end of the downpipe may be angled the wrong way to bolt up to the cat though.. that would most likely be the only modification you would have to do..
Old Sep 11, 2005 | 09:36 PM
TimeAttackFreak's Avatar
Default Re: will this header fit my integra?? (LSRracing95)
also, as mentioned in this thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">
I am not sure that it works the other way around though, yes, a b18 header would fit on a b16 head because the bolt pattern, etc is the same. However, b16s are shorter than b18s when measured from header bolts down to the bottom of the oil pan. So, a b18 header works fine on a b16 (leaves a little bit of room under the oil pan), but a b16 header will often hit the oil pan on a b18 because the bend in the header occurs too early.</TD></TR></TABLE>
Old Sep 11, 2005 | 11:01 PM
watsvtecEK's Avatar
Default Re: will this header fit my integra?? (donutz)
k thanks... damit... it was a hella good price too, like 175 for almost new dc headers!!! ahhh
Gamefreak0109
12
Jun 14, 2023 03:59 AM
RRRRRRRR
Sep 17, 2007 06:26 PM
Honduh Chicken
Apr 19, 2005 07:51 PM
93H22A
Dec 10, 2004 07:01 PM
IntegraBoy04
Sep 11, 2003 02:56 PM
