i need help with ecu for a gsr swap
Old Sep 11, 2005 | 07:42 PM
helpmeplease's Avatar
Default i need help with ecu for a gsr swap
i have a 92 civic with a 98 gsr engine but with a ls computer. iam replacing that ls comp and i want to know what computer is the best for my gsr.
is there anything better than the stock gsr computer?
Old Sep 12, 2005 | 10:22 AM
92Jspec's Avatar
Default Re: i need help with ecu for a gsr swap (helpmeplease)
are you running the gsr intake manifold? if you are, then go with an OBD1 gsr ecu.
if you are running a skunk2 manifold, then go with a chipped P28 hope this helps bro
Old Sep 12, 2005 | 08:14 PM
Default Re: i need help with ecu for a gsr swap (92Jspec)
thanks
Old Sep 12, 2005 | 08:27 PM
im running gsr manifold , what type of odb 1.
odb1 p30 , p72 or p61 spoon.
Old Sep 12, 2005 | 10:23 PM
99teggsr's Avatar
p72 is a OEM gsr ecu, use that
Old Sep 13, 2005 | 07:27 AM
92Jspec's Avatar
yeah go with the P72. are you planning on swapping out the gsr manifold for like maybe a skunk2 or blox?
Old Sep 13, 2005 | 08:05 AM
IHateJDM's Avatar
you can run a chipped p28 with the oem manifold if you want (or can find one cheaper). The p28 doesn't control secondary runners like the p72 does, but that only affects low rpm acceleration.
Old Sep 13, 2005 | 03:30 PM
Default Re: i need help with ecu for a gsr swap (IHateJDM)
i have a p28 from a ls, but my friends had told me that by changing it to the gsr ecu i will gain more hp. i also have another question, i have a jdm dc5 6 speed type r trannie and i want to know what type of problems i might be running to, if i swap it on my stock gsr engine.
Old Sep 13, 2005 | 08:37 PM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helpmeplease &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm dc5 6 speed type r trannie and i want to know what type of problems i might be running to, if i swap it on my stock gsr engine.</TD></TR></TABLE>
You will have a big problem! First, a DC5 K20 tranny doest fit on a B-Series block and second K-series trannys are made for a motor that spins the other way.
Old Sep 14, 2005 | 05:19 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by helpmeplease &raquo;</TD></TR><TR><TD CLASS="quote">i have a p28 from a ls, but my friends had told me that by changing it to the gsr ecu i will gain more hp. i also have another question, i have a jdm dc5 6 speed type r trannie and i want to know what type of problems i might be running to, if i swap it on my stock gsr engine.</TD></TR></TABLE>
if the p28 is chipped with the correct fuel and ignition maps, then it will make every bit as much power as the p72. If you want 6 speed, you got the wrong motor.
DC2SIR-G
Oct 5, 2005 01:14 AM
mr2turbo007
Dec 12, 2004 07:43 PM
meccA's eg6
Feb 1, 2003 03:40 PM
