A/C problem...with no luck
Old Sep 11, 2005 | 06:00 PM
rudeman85's Avatar
Default A/C problem...with no luck
Sorry guys, I've searched with no luck...
My '94 is in perfect shape other than my a/c... My compressor has been making sounds for a while now but has worked. About a month ago my a/c fan went (i'm thinking) cause when the a/c was on the fan wasn't. So I replaced it and it worked fine. Now the other day I went to put the a/c on but the compressor did not kick in nor did the fan. Is there a relay or switch I should be looking at? I noticed my fan wasn't working after the other fan kicked on after the engine was off from a long trip. Any ideas? Thanks!
Old Sep 14, 2005 | 06:44 AM
rudeman85's Avatar
Default Re: A/C problem...with no luck (rudeman85)
anybody???
Old Sep 14, 2005 | 10:13 AM
YeuEmMaiMai's Avatar
it could be one of the following
1. relay
2. Wiring
3. Control Unit
4. ECU
Old Sep 14, 2005 | 04:40 PM
deserthonda's Avatar
chk the condensor fuse in the underhood fuse box ..,if it is ok,, then chk to see if u get power at the red wire that goes to the compressor ,, try those and post results
Old Sep 14, 2005 | 11:07 PM
Jay84ever's Avatar
Default Re: (deserthonda)
Check the blower motor relay! I'm having the same problem.
Old Sep 19, 2005 | 12:23 AM
CB7VTEC's Avatar
You probably have a leak in the system somewhere. If the refrigerant pressure drops too low the A/C pressure switch will basically deactivate the A/C system to keep the compressor from running dry.
mrT
May 12, 2017 08:46 PM
apkskater15
Jun 25, 2013 01:36 PM
Justinmnhall
Jun 4, 2013 11:07 AM
4DRmafia
Sep 1, 2004 02:59 PM
blacksniper
Apr 20, 2004 04:32 AM
