temp guage fluctuating?
Old Sep 11, 2005 | 05:58 PM
myuva3's Avatar
Default temp guage fluctuating?
hey ive got a 96 integra gsr. no engine modifications and 101,500 miles. my temperature guage is fluctuating constantly. whether at high revs or low it doesnt matter. car doesnt overheat but the guage goes from cool to hot back and forth while engine is running. any answers to why this is happening? thanks.
Old Sep 11, 2005 | 06:09 PM
veggiemaster's Avatar
Default Re: temp guage fluctuating? (myuva3)
Check out your coolant sensor. Its the sensor that is right next to your thermostat.
Old Sep 11, 2005 | 06:10 PM
Lauj87's Avatar
could be because of your radiator fan...kicks on when it hits the right temp...then cools it down...but im not sure..my fan comes on but my tem gauge don't fluctuate.
Old Sep 11, 2005 | 06:14 PM
AJ21GSR's Avatar
I've got a 95 GSR and mine's been doing this lately too. I just had some Enjo motor mounts put in and it's done that since... I noticed my radiator tank was empty and filled that back up before I came to work, not sure if this'll do the trick or not, but I';m definately interested in what you find out.
Old Sep 11, 2005 | 06:17 PM
myuva3's Avatar
yea and the car sounds and is running as normal so far
Old Sep 11, 2005 | 07:22 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It definitely should not be doing that. The temp needle should stay pegged just below half, whether moving or stopped, fans running or not, assuming the fans and thermostat are working properly. If it moves around while driving, I would suspect a signal problem, i.e. coolant temp sensor.
Old Sep 12, 2005 | 10:12 PM
AJ21GSR's Avatar
Alright, I just noticed my heater doesn't work now either... Should I check the thermostat or what?
Old Sep 13, 2005 | 12:10 AM
ProjectLSVTEG's Avatar
Default Re: (AJ21GSR)
when my gauge was doing that it was a bad tranny ground.... but dont know what to tell u if ur heater isnt workin... maybe it could still be a ground.
Old Sep 13, 2005 | 04:57 AM
Community Builder
No heat means no coolant is coming through the heater core. Is there by any chance a wet spot on the passenger floor board?
cloudconnected85
Nov 10, 2008 07:31 PM
MikeLuder
Feb 19, 2008 10:53 AM
guymontag
Dec 27, 2006 06:13 PM
parceroreal
Jun 26, 2006 10:56 AM
miksew
Jan 3, 2004 08:10 PM
