D16y7 swap in '89 crx hf..a few problems. help.
Old Sep 11, 2005 | 04:46 PM
Braco11's Avatar
Default D16y7 swap in '89 crx hf..a few problems. help.
EDIT after searching ht, figured out that my cat was going bad. so i solved the smell problem, but still am confused about that hose.
hey htech,
i'm doing a d16y7 swap into my rex and am having trouble with a hose. i used the intake manifold, exhaust manifold, dizzy,etc from the hf and am running obd0 with a pm6 ecu. the hose i don't have hooked up yet is above the thermostat housing (diagonally to the left of it). it's a smaller hose that is connected to the intake manifold. it's almost exactly next to the fat hose that connects the thermostat housing to the intake manifold... i think oil is coming out of the hose...
also, i am getting a really weird smell coming from the engine. when we first started the car, the header/cat area smoked for a while. now, there is hardly any smoke but it smells. not quite oil, but not quite rubber. have never smelled this before. any ideas? maybe a bad cat?
can anyone help me out? thanks in advance.
Modified by Braco11 at 6:05 PM 9/11/2005
Modified by Braco11 at 7:47 PM 9/11/2005
Old Sep 11, 2005 | 06:47 PM
Braco11's Avatar
Default Re: D16y7 swap in '89 crx hf..a few problems. help. (Braco11)
anyone?
Old Sep 11, 2005 | 06:57 PM
HiProfile's Avatar
Is it in either picture?
(is that it, above where #25 connects?)
Old Sep 11, 2005 | 07:05 PM
Braco11's Avatar
Default Re: D16y7 swap in '89 crx hf..a few problems. help. (HiProfile)
thanks but it's not in the pictures. bump.
Old Sep 11, 2005 | 07:40 PM
SOHC-inside's Avatar
hey, i have the same engine in my 88 crx hf, i used an 91Si intake manifold it helps out better i also used a 91 Si tranny, with Si ECU. ?I dyno in @118 whp!
Old Sep 12, 2005 | 12:50 PM
Braco11's Avatar
Default Re: D16y7 swap in '89 crx hf..a few problems. help. (SOHC-inside)
118 whp? damn, that sounds like a lot. that's cool though. i'm going to try and take a pic later on today and post it up.
Old Jan 27, 2006 | 02:01 AM
xd69's Avatar
turbogenetic
Jun 1, 2009 12:20 PM
Frost_1097
Jul 6, 2007 09:38 PM
1hgej1
25
May 20, 2007 07:24 PM
EF8 JUNKIE9
40
Sep 5, 2005 04:47 PM
Project_ED8
Mar 6, 2004 07:51 PM
