B18 transmission swap... ?
Old Sep 11, 2005 | 04:27 PM
BBLineBacker81's Avatar
Default B18 transmission swap... ?
When swapping from an automatic transmission to a standard, do I need to change the ECU and the Harness or is that not neccessary? Thankyou for your help.
-Berg
Old Sep 11, 2005 | 04:58 PM
Kendall's Avatar
ECU yes, harness no.
Old Sep 11, 2005 | 05:02 PM
Lauj87's Avatar
only the ecu needs to be changed..everything else should befine.
Old Sep 11, 2005 | 05:21 PM
MugenDC4's Avatar
I heard some auto > tranny swap you could use the auto ECU and get no Check Engine Light. But in my case I had to change the ECU.
Old Sep 12, 2005 | 06:49 AM
Default Re: B18 transmission swap... ? (BBLineBacker81)
Is there a TCU that needs to be changed as well?
-Berg
Old Sep 12, 2005 | 03:14 PM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BBLineBacker81 &raquo;</TD></TR><TR><TD CLASS="quote">Is there a TCU that needs to be changed as well?
-Berg</TD></TR></TABLE>
no...you'lll now be the TCU ....just an ecu change will make it work...make sure you have the correct mounts...some autos move the main tranny mount...and manuals have it a lil offset in comparision
balbowskie
Engine Management and Tuning
Jul 23, 2012 08:04 PM
civicboost89
Honda Civic (2001 - 2005)
Sep 22, 2008 10:08 PM
Iamhonda
Sep 4, 2003 09:57 PM
gocivicgo
Jun 26, 2003 07:46 PM
lunarcry
Dec 19, 2002 06:58 PM
