B18 transmission swap... ?
When swapping from an automatic transmission to a standard, do I need to change the ECU and the Harness or is that not neccessary? Thankyou for your help.
-Berg
-Berg
Re: B18 transmission swap... ? (BBLineBacker81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BBLineBacker81 »</TD></TR><TR><TD CLASS="quote">Is there a TCU that needs to be changed as well?
-Berg</TD></TR></TABLE>
no...you'lll now be the TCU ....just an ecu change will make it work...make sure you have the correct mounts...some autos move the main tranny mount...and manuals have it a lil offset in comparision
