Timing belt on h22 civic?
Old Sep 11, 2005 | 04:01 PM
LDS's Avatar
LDS
Default Timing belt on h22 civic?
94 civic 4 door h22 w placeracing mounts. Do you pull the motor out to replace timing belt and water pump or do it while its in the car? The valve cover almost hits the shock tower. I do have a few marks on the shock tower im guessing from launching the car and the motor barely hitting it. Any hints would be great.
Old Sep 11, 2005 | 05:12 PM
1700anddroping's Avatar
Default Re: Timing belt on h22 civic? (LDS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LDS &raquo;</TD></TR><TR><TD CLASS="quote"> 94 civic 4 door h22 w placeracing mounts. Do you pull the motor out to replace timing belt and water pump or do it while its in the car? The valve cover almost hits the shock tower. I do have a few marks on the shock tower im guessing from launching the car and the motor barely hitting it. Any hints would be great.</TD></TR></TABLE>
i would just take the driver's side mount off and the the 3 bolts that hold the l bracket to the rear cross member.raise the motor up just enought to get the work done.there is no since in pulling the whole motor out.
harv
Old Sep 11, 2005 | 09:13 PM
RotiEatter's Avatar
Ditto
I have hasport mounts
i un-did the drivers side mount only
used a jack to move motor up and down
Old Sep 12, 2005 | 04:53 AM
fastwanabe's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">I have hasport mounts
used a jack to move motor up and down</TD></TR></TABLE> same here except I have HCP's.
Old Sep 12, 2005 | 04:56 AM
Default Re: (fastwanabe)
i like to have plenty of room,plus i am a pretty big guy,but yes you can also do it that way to.
harv
Old Sep 12, 2005 | 05:31 AM
RotiEatter's Avatar
Ditto
I would have love to pulled my motor out. I thought about buying a new clutch just to make an excuse to pull it, haha.
Old Sep 12, 2005 | 07:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">^
I would have love to pulled my motor out. I thought about buying a new clutch just to make an excuse to pull it, haha. </TD></TR></TABLE>
ha ha good one......
Old Sep 12, 2005 | 08:57 AM
darkdementshun's Avatar
Like a couple others said, just drop down the drivers side or raise it up. I know different mounts position the motor slightly different, but i used the jack method on the drivers side. It can be a pain but take your time and make sure you do everything right. It is worse going back in the second time after you overlooked something simple. I would know.... friggin sucks.
Old Sep 12, 2005 | 06:05 PM
LDS's Avatar
LDS
Thanks guys. Now i know its possible. I do need a new clutch though. It was fine till I ran the car on slicks for 5 passes now it feels different. The car makes enough power that it still kills second up to 55 mph but when i do the 60 mph 5th gear drop it does slip a lil and it didnt do that before.
I think i have at least 6 months of drag racing on street tires But no more slicks for me until i get a clutch.
thanks everyone you made my life easier.
Old Sep 12, 2005 | 08:04 PM
Default Re: (LDS)
thanks everyone you made my life easier.</TD></TR></TABLE>
Oh come on! Just finnish that clutch off the right way! Launch off the rev limiter on some 26"ers. Something is bound to give up.
Old Sep 13, 2005 | 05:26 AM
RotiEatter's Avatar
Ditto
I would buy the clutch and pull the motor and do everything at one time. It would make your life so much easier.
Old Sep 13, 2005 | 01:36 PM
brandond's Avatar
B A N N E D
all i did was remove the driver side motor mount, i also have hasport mounts
H22Stew
Mar 12, 2008 10:48 AM
crxh22project
Jan 20, 2005 03:25 PM
EGhatch22
Dec 24, 2004 10:09 PM
