guage fucked up
Old Sep 11, 2005 | 03:48 PM
hanseljohn's Avatar
Default guage fucked up
I have tryed to put some si indiglo gauges on my 1990 crx si and i didnt like them so i put my originals back on and now all my gauges are f***ed up. i need some help on trying to reset them. I have tryed to turn on the gauges and setting the gauges where they should be.. HELP!!!!!
Old Sep 11, 2005 | 08:08 PM
Kryogen's Avatar
I dont know what really to say, But If you need a new cluster and Hood here ya go..
http://hondamarketplace.com/zerothread?id=1368334
Old Sep 11, 2005 | 08:24 PM
tom_l's Avatar
Default Re: guage fucked up (hanseljohn)
if you pulled off the needles...then you are f'ed.
you really should just buy a cluster. that guys is selling his for a reasonable price.
Old Sep 11, 2005 | 08:34 PM
DOHC_EF's Avatar
Default Re: guage fucked up (tom_l)
I'm just curious, but how would just taking the needles off affect the cluster?
Old Sep 11, 2005 | 08:40 PM
Crimson_Tide's Avatar
Default Re: guage fucked up (DOHC_EF)
try putting them back on in the correct place
-Josh
Old Sep 11, 2005 | 09:47 PM
Tyson's Avatar
ive found lifting the needle up a bit, instead of trying to push them all the way down the stem helps.
Old Sep 11, 2005 | 10:09 PM
BDietrich84's Avatar
Default Re: (Tyson)
you shouldn't have removed the needles.... i assume your talking about those ricey indiglo guages that slip over your original gauges. well all you really can do is with the car off set the coolant temp needle just below the line for the C and fill up your tank, put the gas gauge needle at full. just set the tach and speedo needles at zero while your car is not running.... good luck and if all else fails, buy a new cluster.
Old Sep 12, 2005 | 11:43 AM
hanseljohn's Avatar
jdm16 if you are reading this post i am not yet allowed to im so let me know where at and how much, thank you
Old Sep 12, 2005 | 11:46 AM
hanseljohn's Avatar
hey thanks guys for all info, i have tryied to put needles on but it seems if you take the needles off you are pretty much screwed, well if anyone else has any more info please post and again thanks to all who posted
cinci00si
May 4, 2009 11:20 AM
xkuco
11
Oct 26, 2006 01:52 PM
scrap1ngsr
Oct 17, 2005 08:00 AM
xoutlawz00x
18
Jan 6, 2005 04:17 PM
jdmb16si
24
Jan 10, 2004 04:08 PM
