Anyone have problems removing an axle?
Old Sep 11, 2005 | 01:47 PM
guz's Avatar
guz
Default Anyone have problems removing an axle?
Swapping out both sides, passenger went well. Drivers side has been a nightmare, though. The axle is stuck in the hub/rotor/knuckle thing-a-majig....and won't budge. Even taken the whole knuckle off and set it up on the press with no luck. From what I've read...driver + passenger are the same with the outer joints...am I wron?
Any thoughts?
Also, I was considering just replacing the knuckle setup...but as a trial user I believe I can't post in most of these forums? I believe the user 'tdo' may have what I need...is there any other way of contacting him since all my options are not allowed?
Thanks for any help.
Old Sep 11, 2005 | 06:29 PM
The Phil's Avatar
Default Re: Anyone have problems removing an axle? (guz)
Take a picture of the outboard joint and its attachment to the hub. Did you remove the axle nut? Just beat it with a mallet and it'll come out.
Old Sep 11, 2005 | 06:42 PM
Finest's Avatar
It's probably just rusted in there pretty good. Get a BFH, some WD40 and start hammering.
Old Sep 11, 2005 | 07:25 PM
guz's Avatar
guz
Hammering, pulling, used a pneumatic hammer..and now it's on a press. This biatch won't move at all. If someone could PM 'tdo' for me and point him to this thread it'd be much appreciated. I believe he has a knuckle..and lives fairly close. Thanks.
jguzman_at_gmail_dot_com
NovaRex
Jan 24, 2016 10:45 PM
Mr. Giggles
Jan 23, 2007 06:15 PM
PIC Performance
Dec 4, 2005 07:12 PM
DubyaAye
Oct 29, 2005 05:45 PM
stealthhatch
Mar 21, 2004 01:32 PM
