k 20
h22a, f20b, or k20a......
of those, H22a is by far the easiest swap, and replacement parts are much easier find. none of those motors, however, make torque....and frankly a TSX K24 would be > then all of those
Most likely that would not be too hard of a swap and mounts could possibly be available from hasports so it is worth an email to them. If not then a shop could fab some up pretty easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goowakjai »</TD></TR><TR><TD CLASS="quote">i beleve k24 is from the tsx and tl...i cud be wrong though stoped memorizing every engine from every honda since i grew out of my rice phase(heh heh, middle school was crazy!)</TD></TR></TABLE>
TL is a V6. K24 is in the Accord, TSX, Element.
K24 has good torque but the head is restrictive. The thing to do nowadays is a K24 bottom end with a K20a top end, larger displacement, better flow. I'm contemplating between that, an RSX-S, or the new Si engine in my EG hatch.
Definitely with an accord though, go K24 or k20headk24block. The torque will thank you later.
No, I just don't have access to a K series (still too pricey, i'm waiting till more are available) so I spend all my time learning about them so I can grab it when the opportunity arises...
The new K's in the Si's are an improvement over the old ones (197hp vs 160hp), PLUS a 6 speed tranny with the same helical LSD found in the JDM DC5 R...which is what I want. With a 2100lb car with 10lbs per hp you want 6 speeds and an LSD....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordselux »</TD></TR><TR><TD CLASS="quote">
I'm contemplating between that, an RSX-S, or the new Si engine in my EG hatch.</TD></TR></TABLE>
by new si engine do you mean the k20a3?
mmmmmmmmmmmmmmm.....LSD. that is why i want the k20 swap with all the goodies ,,,,,,,well maby the k20 k24 combo but definately the LSD the k20 in a civic leaves little room for speed bumps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi »</TD></TR><TR><TD CLASS="quote">by new si engine do you mean the k20a3?</TD></TR></TABLE>
Yea, word on teh street is it's a K20az3, but i'm just oozing over the 6speed and LSD.
It has 197hp and 137 ft lbs of torque, but with Hondata KPro, manifold heat shield, custom header and intake, i'll be seeing around 210hp and 143 ft lbs of torque, plenty to scoot that thing. And it can only go higher from there....
oh...and shameless plug..... http://www.k20a.org is definitely a great resource.
just a few things to add....
the TSX head DOES flow well...its no K20a-r, but it has MUCH better ports, and the ivtec works on both sidea of the motor instead of just one on the accord/element
the new Si motor in the US is the k20z3
