COLD START PROBLEM
Old Sep 11, 2005 | 12:58 PM
BK93041's Avatar
Default COLD START PROBLEM
GOT A '00 CIVIC THAT CRANKS TOO LONG COLD STARTING BUT STARTS FINE AFTER IT RUNS AWHILE
Old Sep 11, 2005 | 02:44 PM
boosted civic 2k6's Avatar
Default Re: COLD START PROBLEM (BK93041)
can u be more specific. how many miles are on the car? the condition of motor? last time since you changed oil?
several factors can make it hard to start the car.
1. its freezing outside and ur using the wrong oil
2. bad battery
3. bad starter
4. bad fuel system
5. bad spark plugs
6. bad MAP sensor? <--- or atleast that messes up my car when its really hot out and i got on a short ram intake
theres TONS of reasons. just gotta be more specific about your problem man. good luck.
Old Sep 11, 2005 | 04:37 PM
BK93041's Avatar
Default Re: COLD START PROBLEM (jxmac2o6)
THANKS FOR ANSWERING BACK!! MY '00 CIVIC HAS 51,000 MILES ON IT, JUST CHANGED THE OIL, BATTERY IS STRONG. NEW BOSCH PLATINUM (PRE-GAPPED)PLUGS. I DON'T KNOW AND HAVEN'T DONE ANYTHING WITH THE FUEL SYSTEM OR THE MAP SENSOR??
IT USED TO START ON ABOUT TWO REVOLUTIONS NOW IT TAKES TEN.
Old Sep 12, 2005 | 12:32 PM
BK93041's Avatar
Old Sep 13, 2005 | 05:49 PM
tss201secreto's Avatar
let me know when u finf out wut it is cuz i got the same problem only when engine is cold
Old Sep 26, 2005 | 10:12 PM
Civic168's Avatar
Default Re: COLD START PROBLEM (tss201secreto)
bump for exactly the same problem
Old Sep 26, 2005 | 10:15 PM
ROK801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BK93041 &raquo;</TD></TR><TR><TD CLASS="quote">NEW BOSCH PLATINUM (PRE-GAPPED)PLUGS. </TD></TR></TABLE>
probably isnt the problem but check the gaps on those and make sure they are .44
a lot of people have had issues with bosch's pregapped stuff.
Old Sep 26, 2005 | 10:18 PM
enhancedCL9's Avatar
Default Re: COLD START PROBLEM (Civic168)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic168 &raquo;</TD></TR><TR><TD CLASS="quote">bump for exactly the same problem</TD></TR></TABLE>
civicsi509
Jan 18, 2013 08:39 AM
projekt90ef
May 16, 2012 07:56 PM
axionm1k
Jun 3, 2008 06:19 PM
vanisher
11
Oct 15, 2007 07:00 AM
slowSOHCvtec
Jul 5, 2006 08:38 AM
