non-LSD Q????ASAP
I have a fully built B20VTEC in a EG daily driver and my tranny is a S4C(B16)non LSD, my question is ::is it most likely to brake the differential, since is a non LSD ???i broke mine on friday,the inside casing and the differential pin broke
..............................or would cryotreatment,or another method to make the casing stronger would work????
any suggestions or similar experiences would help
THANX
NA IS BEST!!!!!!!!
..............................or would cryotreatment,or another method to make the casing stronger would work????any suggestions or similar experiences would help
THANX
NA IS BEST!!!!!!!!
thanx dude
does anyone know about cryotreatment(i dont know if i speld that rihgt!!!!!)and the benefits of it and where in so cal can i get it done???
There is alot of "speculation" on cryo treatment with the "supposed" benefits being like 3~9x the reason I say supposed is the really good ones that actively measure those things are usually under private employ.
If your in so cal call gear-speed.com they warranty for like 2 years and use all carbon syncros ect.
ludatic98
Jun 15, 2006 07:05 PM
